Question about Rowenta Perfect Iron
Rowenta Steam Iron Leak
I own a Rowenta Model DZ 9080 steam iron and when it is filled with water and standing in an up-right position, water drips from the heel plate area. The iron is out of warranty, but is relatively unused.
Thanks.
  • 7 more comments
  • karenc414 Jul 24, 2008
    I have the same problem. Sometimes when I go to iron, I find my Rowenta sitting in a puddle. I also find my hand wet after using the iron. Not sure exactly where the water is coming from, but it often ends up on my clothes!
  • leighh Sep 02, 2008
    I bought a DZ9080 and had to take it back to the store the next day as it would NOT stay on even with the normal 'shaking'. I got the same exact style of iron. Unfortunately, the replacement leaked so much, it finally shorted out the iron after only 4 months of use. The repair facility authorized by Rowenta USA is in NY so I had to ship my iron from SC to NY at my own expense. It was delivered in NY on Aug 5th and as of Sept 2nd, parts are still not available.
    I don't really want a 'solution' as I know what I need to do.....go out and buy anything other than a Rowenta. Products must have more than a 'name' to be good.
  • waylen325 Jul 31, 2012
    i have same problem . Ive had three rowentas The last two has been awful about leaking. Guess I've finally learned my lesson. won't buy another Rowenta 1
  • Anonymous Mar 12, 2014
    When ironing sole plate leaks water
    my rowenta iron dg920 is leaking water
  • Anonymous Mar 17, 2014
    How to clean off burnt marks on teflon steam iron plate
  • Anonymous Mar 21, 2014
    the iron is out of warranty. the cord retract was why I bought this this iron. This is not my first rowenta iron
  • Anonymous Mar 27, 2014
    Rowenta Model DW2000. Why does it continually leak water out of sole plate when sitting its heel while ironing?
  • Suzanne Tremblay
    Suzanne Tremblay Nov 07, 2016
    I have had at least 5 Rowenta irons. Why does this expensive one Model 1800W Steamium leak when not being used? It is sitting up and does have water in the well. It says Anti Calc on the box also.
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
  • 6 Answers
The best advise I can offer is to take your Rowenta to the garage, put on safety glasses, grab a #10 sledge-hammer and pound the **** out of it. This will fix the water leakage problem as you won't be able to put water in it ;-) And so much more satisfying then talking to Customer Service.
Posted on Mar 24, 2012
Mine had the same trouble, and I think it was caused by overfilling it. I drained all the water, then refilled it half full and used it and let it sit, both turned on and off. It leaked a very small amount at first, then was done. I think the small amount that came out was water that was left over somewhere inside from the first overfill. I then overfilled it again, and it immediately leaked from the bottom (heel plate area). Good luck!
Posted on Nov 29, 2008
There are 2 problems here. 1). Rowenta irons have a weird tank and you cannot use distilled water in them if you do they will aventually leak. They say to use nomal tap water and if your water is over 12 grains of hardness then use bottled spring water or a combination of spring and tap water. This should fix most of Rowenta leaks.
2). I've got the same problem with a DZ 9080 where when filled full and left standing up the iron will be sitting in a puddle of water around the heal. Mine started happening after I took it in for waranty work, it stopped heating and they had to replace the sole plate. I took it back twice and they just lied to me and kept saying they replaced the tank and fixed it but they never did.
The problem is the top plate on the handle where the steam and sprayer buttons are. That plate or it's seals/catches are damaged and when full it leaks from the button area under the handle. I've ordered a new plate. I'll let you know if this works.
I'm really trying to find a parts break-down for this unit, DZ 9080. When inspecting my handle plate there are 6 plastic clips that should hold this part in place (and seal it against leaks). They all appear to be in good shape, so I'm worried that the idiots that replace my sole plate left out a washer or a spacer so the handle is bent slightly and the clips won't stay latched. I can get this to stay put for a short period and all is well but then it starts slipping out of place and your hand gets wet.
Rowenta sucks, but this is the best iron I have ever used, I really want to fix it.
Posted on Feb 12, 2009
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
    New Friend:
My wife uses DX 8800 and ricently start complaining about water leaking. I took it apart and find out that small rubber pieces from hatch gasket not allowing valves to close completely when needed.
Posted on Mar 07, 2013
    New Friend:
  • 38 Answers
These irons are designed for a person who irons frequently, not a casual user. The user manual should be read carefully and followed or you will have trouble and become frustrated. I purchased my iron from Goodwill store and it leaked. So I downloaded the user manual from their website, read it, and it worked perfectly! Here are some of the instructions from the manual:
After use, unplug the iron, pour away remaining water and set steam control to off.
Open and close the steam control several times to prevent the valve hole in the steam chamber from scaling or blocking up.
Water will leak from a cool or cold iron.Always use untreated tap water, unless your water is very hard. Then mix half and half with bottled spring water.
Do not use boiled, filtered, or bottled water.
Before filling the water tank, unplug the iron and set the steam control to DRY position.
Use the self cleaning function every 2 weeks.
Do NOT use descaling agents, they will permanently damage your iron. If your water is very hard, clean every week.
Do not overuse shot of stem button. Wait between shots.
Posted on Feb 15, 2016
  • 2 more comments
  • Ellen Clayton
    Ellen Clayton Jun 03, 2016
    If it's that complicated to use rowenta irons, I'm getting a different kind!
  • Suzanne Tremblay
    I agree I love this iron, but it should not be so complicated to control the leaking.
  • Anonymous Jan 14, 2017
    All of this info is in the pamphlet that comes with the iron. Following all directions does not stop leakage. I have an old Rowenta that still works. I also own a DW-5090 and a DW-9280. Both of the latter are pieces of junk. Leakage from bottom and back is constant. The 5090 leak
    Ed around the area where the cord comes out. I am a sewist and a quilter. I iron a lot and I will not buy another Rowenta. The product has gone to the bottom of the heap.
  • Raymond Russell
    Raymond Russell Mar 17, 2017
    This is my 3rd Rowenta and I have luved every model but this one started leaking after about 4 times of using. It was a gift from someone so I have no recourse. I spray most of my clothes with a water bottle anyway so I guess this one may work.
Mine leaks as well! really annoyed but i have to say mine didn't start leaking until last year and i've had it since 2006 so i guess it lasted longer than most.
Posted on Sep 05, 2012
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Rowenta Focus steam iron why does it leak
Do not over fill it try using 1/2 the water
May 08, 2014 | Rowenta Irons
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
Rowenta model 1700W. Water leaks out front of iron
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
Rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Feb 23, 2008 | Irons
No Steam From Iron
I can tell you the stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.You've to send for servicing at your nearest repair shop or agent.
Rdgs
alan
Jan 10, 2008 | Rowenta Professional DE880 Iron
Rowenta Perfect Iron Logo
19,078 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
