Question about Cuisinart DCC-2000
Will not brew after a power failure
We had a several hour power failure last night. Now that the power is back on, the coffee maker will not brew. Does it need to be rest somehow? I've tried everything I can think of. The lights are lit--but no brew.
Here's my solution
I went through one unit - had it replaced - (I love this coffemaker) -- anyway, Cuisinart won't replace it again because I'm out of the three year warranty period.
SOLUTION;
I load the coffee into the machine, put 4 cups of filtered water into a glass pitcher - put it into the microwave and boil it:
Pour the water over the grinds and volia!
Screw all the Chinese electronics - but please be careful with that boiling water.
Bob in SC
Posted on Oct 01, 2012
  • 8,596 Answers
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor````
Posted on Mar 20, 2009
Cuisinart dgb900bc. Set timer to brew at 5 45. Have for many years. Last two nights at 5 45 clock goes to 12 00 AM. Does not come on automatically. Turn on manually and brews coffee as great as usual....
I would assume that the chip/timer unit has failed in the unit. Not sure you want to try to disassemble the coffee maker to get at it. Have you tried reversing the a.m. to p.m. (thus the clock would read 5:45 p.m. at 5:45 a.m.) settings and seeing if the machine would brew the coffee normally? (although I seriously doubt this will work, but...)
Jun 21, 2014 | Coffee Makers & Espresso Machines
Won't brew only drop at a time wiuth coffee grounds ]
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 26, 2011 | Keurig Platinum B70 Coffee Maker
No water coming out makes noise and slite water and its not hot
Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
May 12, 2010 | Keurig Elite B40 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
My keurig wont brew
Sep 03, 2009 | Keurig B60 Coffee Maker
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart cod-4000 powers up no brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Dec 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My power company shut my power off during the night and the next morning my $100. Cuisinart Grind and Brew 10 cup Coffee Maker- Black, serial #40219C would not work. Is there any hope for me.
what exactly is it doing or not doing ??? any lights come on when you attempt to use it. chances are it just needs to be reset (unplug it for about ten minutes then plug it back in).
Robert
Sep 22, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore coffee maker wont brew model #81006
This coffee pot was recalled,I just took mine back to sears essentials last night and they replaced it with the new improved one,they just got them in.Good day,Sandi
Jul 23, 2008 | Kenmore KBC12 Coffee Maker
Coffee Makers & Espresso Machines Logo
358 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
