u may have willingly or unknowingly written wrong code for many times due to which it is locked.input ur password followed by # if it again shows code error then remove battery and switch on again
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site www.theunlockspot.com/nokia-dct-master-code-service/rs10wp10 , it has the best services for the master reset code for your Nokia 7210 model mobile.....I hope that it may helpful to you....
HI FRIEND GIVE A CODE TO YOUR MOBILE THE CODE IS *7370#THAN YOUR MOBILE WANT ONE MORE CODE WHICH IS HIS DEFALT CODE LIKE 12345 OR WHICH YOU SET ON IT THEN YOUR MOBILE ASK YOU THAT REFRESH IT THEN YOU PRESS THE YES BUTTON AND YOUR MOBILE IS TRUN OF AND ABOUT ONE OR HALF MINET IT WILL TRUN ON AND YOUR MOBILE IS TOTLY REFRESH LIKE YOUE BROUGHT IT NEW
there is one option in the mobile Sim Lock.. i think your doughter hit Sim Lock option. don't enter the wrong pin code because as you enter the wrong PIN code 5 times Sim will block Sim lock having the same password as your phone password default password is given in the guide book of mobile see it from there & open the sim lock if you don't want the same problem again then go to the settings there is one lock option ... hit on the sim lock ... then off it.. the lock will not appear in future..
Hi Friend, I Kindly let me know ur IMEI of your mobile.I can be found by typing *#60#.U will be receving a serial no kinly provide me i will provide the solution
To restore Factory Settings for Nokia mobile *#7780# reset to factory settings. Your IMEI: 355690003774394
Your Nokia Master Code: 7015163201
Steps to type Master Code:
1.This is master code.It has to be entered when your phone is started and asks for code..(security or master).. 2.If you type 5 times wrongly,the phone will get whole locked.. so,try 1 time. 3.If you fully typed 5 times wrongly ,you have to get a software tool to unlock and that costs greater than the phone you got.. so,try 1 time and let me know..my email id:[email protected] "This will not bypass the PIN code as that is set on your SIM and always varies." "Rate high if you are satisfied" "Thanks"
