The nortel wlan handset 6140 is displaying an error called "flash config err" and i am unable to get the phone to do any thing else-tried battery out and on/off.
Unable to Call, Try Again
The phone line is supplying a certain amount of power. If you open many parallel channels the power is distributed among active phones. The more sets there are the less power each one gets.These are the physical principles behind the limitations on the number of ringers a single line can activate (Ringer Equivalence Number)
As to the need to be using 3 or more sets on the same line and at the same time, I have a hard time understanding that.
For a landline, your phone company can activate 2 numbers, as it can enable A/DSL on your phone line.
Dec 18, 2013 | VTech Communications CS6409 - cordless...
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
When I pick up my phone line 6 lights up is there any way to have line 1 light up when I pick up the phone?
Phone is programmed as:
-Access to Pool A = Y
-Primed to = Pool A
When somebody dials 9 or picks up handset it will go to the Prime To noted above which is Pool A.
6 lines are in Pool A, you cannot change the order......it will always select the bottom line.
You need to change Prime Line to = None, then when a line is ringing it will answer the first line that rang.
If you know how to program its under Config/SetXXX/LineAccess/PrimeLine otherwise you need to call a tech/vendor in for this.
Oct 17, 2012 | Nortel M7324 Refurbished Norstar System...
-unable to connect to wireless -unable to open internet explorer msg states "unable to connect due to error on this site" (yahoo) -Is there a reset botton for wireless -Called my internet Co,...
Your problem may appear from a not properly enabled WLAN card.
Make sure the Wi-Fi swithc is in ON position and on your laptop keyboard try the FN+F8 combination to have displayed the wireless card status. The WLAN card has to be ENABLED to be able to connect to the Internet. The combination done will make appear on your display a window with some options available; choose that option that enables your wireless card.
Also check in your computer's DEVICE MANAGER if your WLAN card is working properly. To do so follow these simple steps:
1. START and click on SYSTEM;
2. in SYSTEM option click on DEVICE MANAGER;
3. on DEVICE MANAGER option go at NETWORK ADAPTERS and see if there your wireless card is indicated and it shows that it is working PROPERLY;
4. if an UNKNOWN DEVICE is indicated then try to find the right driver for you notebook model and WLAN card model;
5. install the driver then REBOOT and recheck in DEVICE MANAGER if your WLAN card is displayed properly this time.
Mar 02, 2011 | Toshiba Computers & Internet
Getting a ' Fatal Error ' on display (W6120) and after rebooting the handset an error code of 0x000f appears.
The Fatal error "errcode 0x000f" is displayed on the handset and has detected a fault from which it cannot recover. This is internal problem within the handset. You'll need to return handset to Polycom.
Dec 13, 2010 | Nortel WLAN Handset 6140
I have a nortel 1120e but I have a problem. When I make a call I can not hear the other person but they can hear me my. How can I fix it?
I'm not familiar with this particular phone, but our Nortel system phones sometime act up. The trouble is almost always the cord or handset, especially if the phone is wall-mounted and the handset has taken a dive or two to the floor. On rare occasions we've had a phone go bad, but not often.
Try another cord first, then swap handsets with another phone if you can. That will probably solve the trouble.
Oct 22, 2010 | Nortel 1120E
Handset will not work
Try swapping the handset and cord with a working phone. Those handsets are known to loose the transmitters. As for the ringing, have someone make an intercom call to your extenxsion. Do not answer the call...while the light is flashing press the volume up button several times. www.dyna-tech.us
Hope this helps
Mar 23, 2010 | Nortel T7316E 2-Line Corded Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
Problem with Nortel WLan handset 2210
must drop the whole programing and start from scratch. it called dumping.
Feb 14, 2008 | Computers & Internet
Nortel wlan handset 2210
that is done through CS 1000E switch.
YOU WANT COMMANDS PLS LET ME KNOW.
Feb 08, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
