Question about Samsung Digimax S600 Digital Camera
Card Locked have put new batteries in, switched on to take pictures then it comes on screen Card Locked. Removed batteries and card started again, sometimes it works, but mostly I have a repeat performance. Nothing in the book to explain.
  • sharonandjad Jul 27, 2008
    After two years of no problems the card has suddenly been re-put in and say it is locked. Samsung Digimax S600 Digital Camera.
There is probably a little slide on the side of the card that locks it. Take the card out and slide it back to the unlocked position.
Posted on Sep 17, 2008
I removed Card as well as batteries, then started again which seems to have worked. I will get a new Card to see if that is what is causing problem.
Posted on Jul 15, 2008
Samsung le19a656a has sound but no picture ? has picture sometimes for a minute or so when turned on and off
Just switching off and on is not enough. You could try one step further. After switching off, remove the battery and memory card for a little while just a few seconds should be enough.
To make sure the memory card is still working, put it in an external memory card reader and look on the computer you still have pictures on it. If the card gives an error in the computer, try recover software, to retrieve your pictures. If the card looks ok, replace the memory card and the battery and switch on again.
But also make sure the battery is charged.
If after this still the same error occurs you should visit a repair centre, or start saving for a new camera.
Jun 10, 2014 | Samsung S860 Digital Camera
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
My my son removed my memory card from my computer without first asking for it to be removed. All my pictures are now on the card and I can't open it. How do I unlock the card?
Welcome to FixYa
Whats Showing when Trying to Open Pictures in Card.You can Open it by Putting card again to PC to view pictures.
If card is Damaged then you cant see it any more...
If card is LOCKED-It need to be Unlocked with Unlock device-then All data will be deleted..
I dont think it is locked....ONLY by just Removing from PC -card will not be Locked...
You can Open it manually...Let me know if you need further assistance...
Thanks for Connecting FixYa..
Aug 31, 2010 | PNY 2GB microSD Memory Card
AFTER INSERTED A NEW BATTERIES IN THE SCREEN SHOWS CARD LOCKED, HOW I CAN FIX THAT
Try taking out your batteries and then taking out your memory card. In memory card you can see a small button at the side you need to slide that to unlock your memory card. Put back in batteries and memory card. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
Mar 29, 2010 | Canon Powershot SX110 IS Digital Camera...
"Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
Casio exilim 8.1 card is locked
Hi!
Can you check if there is a small push button on the memory card itself? It could that it is currently on write-protect mode.
Aug 29, 2009 | Casio Exilim EX-S600 Digital Camera
CASIO camera says screen card is locked, mem. card is on unlock..
thank you very much, it was the card when i removed the card it worked. again thank you
Jun 06, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Card locked but its not
Memory cards are funny things that can sometimes currupt for various reasons i suggest you just buy a new memory card.
Try to retrieve the pictures you can get on your computer before you dispose of the old one.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
Samsung Digimax S600 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
