Question about Lands Phones
Both phones are flashing base 1 with no ring tone on a bt studio 1500
  • 1 more comment
  • Anonymous Dec 27, 2008
    Phones continually flashing base1
  • yamuna_rai Apr 07, 2009
    have the same problem, on the screen base 1 is flashing no ring on the handset only on the base
  • john938 Apr 20, 2009
    All handsets are flashing base 1. cannot get a dialling tone.
Hi
Had the same problem with my BT Studio 1500 phones both flashing "BASE 1" . Again could not find solution on web! BUT phoned the free BT helpline on 08001456789.
They told me to switch off electricity supply to the base unit then switch it back on.
(The fault is due to the base unit losing the signal and just needs to be "rebooted")
Hey IT WORKS!!!!!
Don't buy a new set of phones!!!!!
Groucho
Posted on May 16, 2009
No dialling tone and cant receive or make calls base is ok and will ring phone to search for it
The base is not connected correctly to your phone line or there is a problem with your phone line. Check with your provider.
Nov 04, 2014 | BT Freestyle 710 Cordless Phone - DECT 1 x...
How do you register a second phone to the bt studio 1000 phone
1. Check the manual of your new handset on how to set it to registration mode.
Then on your BT Studio Base
2. Press and hold the base (page) button for at least 10 seconds until you hear the validation tone. then release. That's it.
for this model, you can only use up to 2 handsets.
hope it helps.
May 05, 2011 | Cell Phones
Bt xd 1500 keeps flashing base 1 whats the problem with it
I can`t find a manual for your phone.But have looked at one similar.
When the base is flashing it can be that you are still on the phone.
Or it can be when you have missed a call,answer phone or sms message.
The base may flash when the phone is charging.
Oct 28, 2009 | British Telecom BT On-Air 1300 Executive...
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
BT Studio 3500, Base station, flashing telephone. Base staion handset, flashing message icon 2nd handset, flashing telephone and handset. Why the flashing and how do I cancel all the flashing.
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
Sep 17, 2008 | Lands Phones
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
1,887 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
