after unplugging the unit and then properly removing, cleaning and placing filter back in and placing the brush switch to the on position the unit brushes would still not turn. I looked up under the unit and noticed a white turbine that the brushes connect into would not turn when the unit was turned on. Is this any indicator of the turbine going bad on the unit?
I had same problem and it was the turbine assembly. Part was only $28 but with labor it cost me $140 total. Plus it took over 5 weeks for my vacuum repair shop to get the part. In hindsight, I would have just spent another $100-$150 dollars and bought a new cleaner because now I'm having issues with the water tank leaking and I have to replace the valve assembly. Seems like it's always something.
Was this helpful?
Yes
No
Popular Solutions for Hoover F7425-900 SteamVac V2
this is a 6 brush model, the brushes do not rotate, the filter is clean and the switch is in the on...
(More)
this is a 6 brush model, the brushes do not rotate, the filter is clean and the switch is in the on position
i have the hover steamvac spinscrub widepath model f7410900. works great but now the scrub brushes...
(More)
i have the hover steamvac spinscrub widepath model f7410900. works great but now the scrub brushes underneath that do the cleaning dont spin anymore during the washing setting for the carpets.
2nd time I used Bissell Pro Dry carpet cleaner ; plugged it in, turned it on, water pours out the...
(More)
2nd time I used Bissell Pro Dry carpet cleaner ; plugged it in, turned it on, water pours out the bottom of the machine.
