Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52inch will not remain on...
In the last couple of months my television would turn off on its own, all I would need to do is turn it back on and it would work fine. Yesterday it turned off again on its own and when I attempted to turn it back on it would not. The green light would come on for about three seconds (did not blink, it was solid), I heard noises like static and a clicking sound, and then the tv would turn off. This continues to happen every time I attempt to turn it on agian. I have unplugged the tv for about 1 minute and plugged it back in and got the same result. Also you should know that I have other electronics plugged into the same outlet and they still work so its not the connection.
  • Anonymous Feb 11, 2009
    I have the exact same problem only mine has been shutting itself off for over a year now with no other problems. Then today it wouldn't come back on when I pushed the power button. Also there is a beeping noise coming from the back of the TV. Took the back board off the TV, blew out the dust (alot of dust as its 5 years old), and couldn't see a visible problem. Or where the problem was coming from. Hate to have to spend alot of money on this TV, maybe I will just get a Plasma of same size or Projection Screen. This is the year for HD anyway and this TV is not compatible for that or Blu Ray. Maybe its time for a change. Besides it's pretty hard to get a TV that size in a car to go get fixed.
    Scholar:
  • 154 Answers
Just after your cord goes into your tv there is a box that regulates the power supply the tv acctually gets (helps with surges and the like) it maybe that this part is faulty and needas replacing. Have had this problem befor and it turned out that was it. Very expencive to fix though.
Posted on Jul 23, 2008
My RCA D52W19 HDTV Ready TV will not turn on. The power led comes on three times after pressing the button on the tv itself or attempting to power on with the remote. The condition has been getting worse...
Hi Aaron,
I just want to ask you something before I give the solution, does the unit gone to start-up problem (needs warm-up before it finally turn on, needs to pressed the power button key several times, needs to unplug from the outlet and plug it back in)before, you have said that you've encountered it last few months?
Jdvillanueva
Sep 29, 2011 | RCA D52W19 52" Rear Projection Television
My 52inch floor model turns on then immediately turns off? rca hdtv
Thats usually caused by failed or cracked solder on the flybacks connections to the deflection board. I would check the solder first if that doesnt solve the issue you may need to replace the deflection board.
Jul 24, 2011 | RCA HD56W66 56" HDTV
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
Sep 30, 2009 | RCA Televison & Video
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
RCa P52926 52inch
CHECK THE SIMPLE THINGS --MAKE SURE THE PLUG IS STILL PLUGGED IN AC...IF YOU HAD SOME POWER INTERUPTIONS ...MAY HAVE BLOWN THE MAIN FUSE BY THE POWER CORD.DO YOU SEE ANY LED LITES ON THE FRONT OF TV..POWER INDICATOR??? .REMEMBER ,ALWWAY S UNPLUG THE TV IF YOU TAKE THE BACK OFF...TUNICA
Sep 04, 2008 | RCA P52926 52" Rear Projection Television
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
