Try un-installing the wireless adapter, and then reinstall it back. If this does not work, check out the configuration in both the router and in the computer. You will have to connect the computer directly to the router to check out the router's configuration.
It is also possible that the wireless adapter has failed. The only way to verify that is to try another one.
WPA requires an group of alpha numeric sequences for encrypting data between the wireless card on the computer and the wireless access point/router.
These sequences are hard to remember when setting up the wireless Access point/router soa passphase is used to generate these alpha numeric sequences, just use any english phrases such as "I love you 2 pieces", then this can be used to configure your wireless card on your computer.
Okay, if it is a wireless repeater, you simply cannot, the WRK does not have such capabilities, but WIRED, that may work.
By default the routers IP is 192.168.1.1, so turn off the DHCP of the WRK, then change the IP to 192.168.1.something else. for the cable routings, from the primary router's ethernet cable should be plugged in to any LAN port of the 2nd router.
then you can relocate the 2nd router to where it has to be as long as the cable reaches it (not longer than 200 feet)
for the wireless settings, just make a different wireless networks for both routers.
do one thing install the driver of the router card in ur note book by cd is give with the card.after install the driver card restart the notebook then you get the icon in taskbar wireless signal.then after go to linksys router first go the network place right cilk propersities after that u see the local area connection right cilk properties then go for tcp/ip protocol then properties after that u give the ip address 192.168.1.50 and subnet mask is 255.255.255.0 aND DEFAULT GATWAY IS 192.168.1.1 THEN GIVE OK OK OK. then go start >run>type ping 192.168.1.1 then enter after that u show the black screen in that given reply or request time out.if the reply is came then go to internet exlporer in address bar type 192.168.1.1 then enter asking user name and password then give usermane admin and password is admin after then go wireless cilk it then enable the wireless in that you can give the wep key also.
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP 2. Turn off NAT 3. Assign a fixed IP that is in your Class C Block 4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
