My mothers computor monitor screen wont come on, Its a Hp vs17e monitor thwe screen stays black
  • bmfsports Feb 03, 2009
    I'm having the same issue. The monitor gets no signal at all. It works when hooked up to other computers, but not this one. Ideas?
    Sergeant:
    Champion:
  • 327 Answers
Monitor could be blown or the video card might now be anygood or try to turn up the brightness on the monitor .....
Posted on Jul 14, 2008
I turn on the pavioliion dv4 and there is no screen. i hear it on but see nothing
http://www.ehow.com/how_6162556_change-screen-brightness-hp-laptop.html This is a link to with instructions on how to change the brightness of your computor. It may be on too dark a setting now. Another possibility is that the screen has worn out and needs to be replaced. A third is that the computor itself is not working properly now, although you say you hear it on. If it is not a question of brightness (the setting is too low and now everything looks dark), I would take it to a place which repairs HP's.
May 03, 2010 | HP Pavilion dv4000 Notebook
Do lcd monitors over heat and shut off screen image while monitor is still on. i have a dell monitor and an hp vs17e. the hp monitor has started dropping the screen, going to black. i can turn it on and it...
It is possible that your the lcd inverter board is failing or possibly the back light, i suggest taking the back cover off the monitor and checking the power board for leaking or slightly buldged capacitors, to spot this youll have a dark liquid traces on the cap or on the board, the top of the cap must be flat not bulged, if there are any they'll need to be replaced, you can get them from electronic stores like Maplins, and if you are able to use a soldering iron desolder the the ones of the board and solder the new ones on. Make sure you get the exact farad rating of the caps, it dosent matter to much about voltage as long as it is equal or above the voltage stated on the cap. Also insure that they are replaced the correct way around, check this before desoldering from board.
Jan 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Jun 14, 2009 | HP Computers & Internet
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
HP vs17e automatic auto-adjusts randomally.
well why not try the monitor on any other computer
if it fails there,
bingo bad monitor.
easy no?
that shifting is bad. real bad,
if the problem in only on your PC.
then the Video (card or GPU chip) is bad.
you never said what you are plugged into
1981 to 2017, 10,00000 systems. made.
Mar 17, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
My hp dv6000 monitor wont turn on.
It sounds like a fault in your screen displays, or worse your motherboard. Take it in for a look because the problem is hardware and it needs to be checked and replaced.
Hope This Helps
Nov 20, 2008 | HP Pavilion dv6000z Notebook
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Goes to sleep
Hi
Pls check the power option settings in control panel.
Also pls check if the power management options for keyboard and mouse in device manager are enabled or not.
Pls try to create a new profile and check if the sleep mode is working in the new profile.
Pls try a System restore if the above steps don't work.
Dec 24, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
