Question about Compaq Computers & Internet
I have a compaq series 2930A hand held and its gone into admin lockout mode is there anyway i can generate this code online rather than downloading a programme
  • 177 Answers
If its still under guarantee try hassling the shop for some info where you purchased it.
Posted on Jul 14, 2008
I have a xantrex TR2424-120-60 inverter and I was gone and had no sun and my batteries got down to 22.4 vdc and had a fault of F08 and when I started the generator the charger wouldn't start charg
http://www2.schneider-electric.com/.../TRACE%20Operation%20TRxxxx%20manual.pdf
As I suspected this fault code refers to a battery problem it or they have fallen below a voltage which creates a problem for the chargers safety features.
Charging by an external (less fussy) charger or the need to replace it or them, if the unit has been active for a long while then batteries degrade and will not fully charge so should be changed anyway.
Hope this helps...........
Oct 23, 2017 | Xantrex Technology Trace Series Inverter /...
How do i use a emachine restore disk on a compaq
You could try booting into safe mode and restoring your computer to a time before the update was installed. Was the update KB977165? If memory serves, this update may crash your system when you are infected. Read more here:
http://blogs.zdnet.com/hardware/?p=7377&tag=nl.e539
Try tapping F8 when you turn on your computer, select "Last known good configuration" and see if it will load the OS that way. If so, you will want to run some scans. I recommend Malwarebyte's Anti-malware to start:
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
And then run an ESET Online scan
http://www.eset.com/onlinescan/
If last known good configuration doesn't work, try F8 boot again, selecting "Safe Mode", and go into system restore to restore your computer to a point before the update was installed.
in XP it is START>All Programs>Accessories>System Tools>System Restore
Did this resolve your issue? If so, please rate it. ty.
Feb 27, 2010 | HP Compaq nc6000 Notebook
I have a Compaq notebook and the keyboard is not working under the administrator. It works fine under any other user. I've tried to update and uninstall drivers with no success. Also I cannot hit...
if the keyboard is working in any other user account . The user account has gone corrupt. You can recreate a new admin account. But before you do that back up all the my documents folder.
1. Restart the computer and press the F8 key a couple of times before windows starts
2. Select safe mode and press enter
3. Select the admin account and log in
4. Click on Yes to continue to work in safe mode
create new account in windows Xp
http://www.microsoft.com/windowsxp/using/setup/winxp/accounts.mspx
Create a new account using windows vista
http://windows.microsoft.com/en-us/windows-vista/Fix-a-corrupted-user-profile
Once the new account is created you and delete the old admin account
Thanks
Proton
Feb 06, 2010 | Compaq Presario Notebook
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Our minolta 4000 is asking to enter access code
Someone has gone into the admin mode under the user mode and turned on copy track. You need to go back into the admin mode under the user choice section and turn copy track back off.
Dec 10, 2009 | Minolta EP4000/5000 CS/PRO Copier
Is there anyway to delete programs from a Palm TX from the desktop?
HI,
Yes there is a way to delete programs. Take your TX and in the upper left of the screen you will see the time. Tap the time with your stylus. A drop down menu will appear. Tap "DELETE". Your TX will generate a list of all the programs and applications on your hand held. Once that list is generated tap or highlight the one you want to delete and the tap the delete button at the bottom of the screen. Once you have deleted all the programs you want tap done and then do a hot sync. They should be gone from then on. If you find this helpful please rate me. Best wishes.
Sep 14, 2009 | Palm TX Handheld
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
Hand signal coming up when trying to take picture
The hand icon means you don't have enough light to take a hand-held photo. You need to either increase the light (take the photo in brighter light, such as outdoors in the sun), use flash, or a tripod.
Some cameras have a mode that will let you shoot anyway, but most people are not happy with the blurry photos they get when shooting when the camera warned them with the hand icon so you are better off not using that over-ride mode.
Dec 31, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Range goes into lock out mode for no reason
I posted a similar problem earlier today but never saw it come up. Anyway I found the problem for me. My problem was a "LOC" display came up when I plugged the stove in after bringing it home (bought used off craigs list). This made the stove top inoperable, no gas supply.
SOLUTION:
There is a Cooktop Lockout as part of the night light switch which you hold down for 3 seconds to activate or deactivate. This is not the same as the Control Lockout which is next to the switch I am describing. Anyway doing this will make the "LOC" display go away and you will hear the gas valve activate or deactivate respectively.
Jun 14, 2007 | Whirlpool GS563LXSS - stainless Steel Gas...
Computers & Internet Logo
524 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
