Question about Whirlpool Washing Machines
I have the Whirlpool Gold Series. On the low or gentle selection it still spins my clothes so hard they are wrapped around each other and stuck to the sides of the tub. My knit shirts come out so wrinkled that no matter what I do, line dry them or use the dryer, they never smooth out. It seems like the spin cycle for knits is just about the same as it is for heavy clothes and towels.
  • 41 Answers
Spin speed is the same just doesnt run as long on delicates cycle
Posted on Jul 14, 2008
Kenmore won't spin
You should check the filter but you must check thoroughly as generally its something that is wrapped around the filter stopping it.generally its elastic or laces or string from hoods
Feb 22, 2013 | Whirlpool Clothes Washer Timer - W10201447
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
How does one remove the handle cap from a vintage 2001 Moen series 7100 kitchen low-arch faucet. The handle cap looks like part #96790 and has no small screw that would require an allen wrench and no...
The problem is probably hard water build up or dried soap or some other foreign matter stuck between the cap and the valve/cartridge. It is simply a bad design (if you ask me) and moen does not make a special tool to remove it which is a surprise since they make a special tool for everything else :(. since you probably don't have a rubber/plastic pair of channel locks, i would get a regular pair of channel locks and something like that rubber thing you use to open jars or a thick dish cloth to wrap around the cap and then use the channel locks to gently coax it off. you could also tap it gently w/a mallet or small hammer and/or spray it w/a little WD-40
Jul 24, 2011 | Moen Home
Clothes wrap around washing machine agitator causing it not to spin
clothes wrap around agitator. making clunking noise only while agitator is working
Feb 19, 2011 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle doesn't spin clothes well
pump stuck with the lint just tille the washer open 5 or 6 screws on the pump clean the lint wrap around the wheel pump it will fix the problem good luck.this machine is a lemon get sue by some other state the company make it already lost the case why they still sell in cali
Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes wrapping under agitator
Somewhat inherent in this design. You can try to carefully unwrap the clothes by gently rocking them back and forth to see if you can release them, or gently spin the drum while you tug (not too hard!) on the stuck clothes. The wash plate seal might be compromised, but if you start taking the inner workings apart you have to replace the gasket set. I have not tackled this on my unit yet though I have replaced the old pump motor with the improved one (single piece instead of 2 pieces), and I have gotten adept at taking the unit apart from the bottom to remove draw strings which get sucked into the pump impeller, jamming or clogging it. The wash plate seal might be getting old - I think mine probably needs to be replaced but doing that will require more extensive repairs than just putting in a new seal. The service manual warns several times about replacing the proper seals, gaskets o-rings and/or grommets if you remove the outer or inner wash plates, to avoid compromising the water tight seals and causing damage to the U-joint assembly that gives the washer its characteristic wash motion.
Apr 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
