Question about Acer Aspire 5500 5570-2609 Laptop
Acer orbicam mulfunctioned
Why my acer orbicam suddenly malfunctioned,my laptop is aspire series 5570
  • 3 more comments
  • welmags Jul 14, 2008
    I can't disconnect it since it is bulit in webcam
    malfunctioned,in the sense that every time i want to use it,it wont work,worse,there's a sound that wont stop and i have to tilt my cam just to get rid of the sound
    I have done it all before but to no avail,maybe i shoud need a driver software from the acer factory website and download it,as you told me,thanks
    it's already out of warranty
    sorry,I just acant rate the solution because everything i want to know for fixing my problem is just not there,i've done this all a year ago but it just doesn't work,as a matter of fact i already uninstall it in my system but the problem still pops up evrytime i open my laptop,that's why i seek assistance,so maybe i still do what i always does everytime it pops up with sound,just tilt the built in cam so the sound will dissappear.
  • 4,234 Answers
I'm sorry to say that this problem won't be fixed with software. From your description, I think that the ribbon cable that connects to the webcam itself has a small hairline crack in it and needs to be replaced. If a ground connection is one of the cracked traces, then the sound you are hearing is what is called crosstalk. Without the grond connected, the data lines act like antennas and pick up all kinds of interference noise. This unit will need to be opened up and the cable replaced. That should silence the noise and also allow the camera portion to work as well. Since you have removed the software drivers, you will need to re-install them once the cable has been replaced.
Hope this helps to at least explain what is happening.
Dan
Posted on Jul 14, 2008
    Master:
  • 788 Answers
  • 2,071 Answers
Click this for more information:
The Acer solution for the OrbiCam Problem
  • 319 Answers
There is a ton of information from this website.
Please let me know how this progresses.
Brian
  • Brian Berndt
    Brian Berndt Jul 14, 2008
    Could you mention whether you are running XP or Vista, and if Vista, was it an upgrade, or original install?
  • Brian Berndt
    I am afraid that ABRSVCS is probably correct. Please follow his advice.
    Genius:
  • 1,447 Answers
Hi-
Make sure all drivers are updated, and if you have the warranty for it might as well call manufacturer for support. Thanks for using Fixya!!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 14, 2008
    Hi-
    Check this site, click HERE and download the recent driver for your cam
    hi-
    Or better have it service by an expert on this, because chances are there are some wires that are pinched on something in which its making up the sound and by adjusting it, it goes away.
    Thanks for using fixya though, have a nice day!
    President:
  • 1,257 Answers
HERE IS THE SOLUTION : DON'T FORGET TO RATE THE SOLUTION
CLICK ON THE LINK AND FOLLOW THE PROCEDURE
LINK
  • Acer Master
  • 13,433 Answers
Laptop still under warranty? warranty would get it repaired for you free if you still have that?
    Guru:
  • 1,894 Answers
Malfunctioned in the sense?
please tell the problem in detail
  • 1 more comment
  • dewan nafees ahmed Jul 14, 2008
    malfunction is a very general term for describing a problem. and hence it would be kind enough if you describe the problem in detail sir.
    thank you
    sound due to camera position?? this sounds like a hardware issue. and i think you will have to dismantle the unit to check up this problem.
    so please start the repair only if you are good in electronics and laptops.
    thank you
    good luck
    "there's a sound that wont stop and i have to tilt my cam just to get rid of the sound"
    this is enough to say that the problem is nothing to do with the software and the drivers.
    why dint you take this to a service center from one year??
    this is a clear hardware fault from my point. this can be even some small problem like a connection interface problem.
    is you want to avoid the cost of going to a service center then i would either recommend you to take risk and disassemble the unit to repair it.
    else leave the problem as it is. it may clear itself in time being.
  • Acer Master
  • 19,396 Answers
Try disconnecting and plugging back usb
  • 2 more comments
  • Ginko
    Ginko Jul 14, 2008
    Try first disconnecting computer power cable for 10 minutes and then plug it back. Also disconnect the usb cable, and then re-connect it, eventually using a different USB port.
    If this does not fix it, then you will need to reinstall drivers.
    Unplug the cam from USB, put inside driver disk and start again software and driver setup program.
    Disconnect the cam from USB before installing driver connect it back only when required explicitly by setup or after installing driver.
    If you do not have the disk you will need to download driver software from factory website.
    I
  • Ginko
    Ginko Jul 14, 2008
    Then reinstall the drivers provided for orbicam on Acer website. Before doing this disconnect laptop from power and remove battery for five minutes, this can fix it.
  • Ginko
    Ginko Jul 14, 2008
  • Ginko
    Ginko Jul 14, 2008
    Use the link above, click 'drivers and utilities', either on Vista or Win XP, depending on your system. There you will find Orbicam drivers listed in a drop down menu.
Model5742 web cam not working
The Acer OrbiCam is a built-in 1.3 megapixel webcam mounted at the top of certain Acer laptops. The webcam can record video clips and integrate with instant messaging software. If you are trying to use your Acer OrbiCam but it won't connect, the driver--a small software file that tells the webcam what to do--may be outdated. Acer provides webcam driver update pages for the Aspire 9300 and Aspire 5570 versions.
1.Go to the Acer 5570 or Acer 9300 Driver Download page (see Resources).
2.Click "MS Windows XP" or "MS Windows Vista" on the drop-down menu, depending on your operating system.
3.Select "Acer OrbiCam Bison Driver" from the menu.
4.Click "Save File > OK" and wait for it to download.
5.Double-click on the downloaded setup files to install the driver.
6.Go back to the Acer Downloads page, and select "Acer OrbiCam Driver Bison Utility 1.0.0.13" from the drop-down menu.
7.Click on "Save File > OK" and wait for it to download. Double-click on the downloaded setup files to install the driver.
8.Restart the computer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Acer Aspire 5610-4648 Notebook
Install aspire 5570\Acer OrbiCam
You will need to go to the Acer website to download the driver for your OrbiCam. The following link will take you to the site:
click-here
Once you click on the link the webpage will open up and ask you to choose your laptop. You will highlight Notebook, then Aspire, then your model # 5570. A list of all of your drivers will then appear on the page. You will scroll down to the list of Camera drivers, choose the correct manufacturer of your OrbiCam, and then click on the Download icon. The webpage will then allow you to download the file.
The file will be packed in the .zip format. If you don't already have a utility to unpack the archive you can go to this website:
http://www.7-zip.org/
The 7zip file is a free file. Download the file to a location that is easy for you to get back to. Saving it to your Desktop can make it easy to work with. When the download is finished just double click on the icon, and the program will automatically install itself.
May 14, 2011 | Acer Aspire 5500 5570-2609 Laptop
How can i install the acer orbicam of my laptop aspire5572
Download the webcam drivers from Acer Support Site
Select your model from the above link & confirm your model.
Choose the Aspire 5570 series,
Then select your OS to download these drivers.
As for your Laptop model, there are 3 different webcam, ie Bison, Logitech & Suyin, so select the correct drivers to download & install for your system.
Hope it helps.
Apr 13, 2011 | Computers & Internet
My Acer OrbiCam not installed ,My laptop is Acer Aspire 5630
click here
If you have vista or winxp you can download driver from above link then install in computer.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5570 WebCam not working [logitech Orbicam]
unplug cam, restart pc then plug in should work fine.
If not unistall the webcam drivers and install them again :)
Apr 21, 2009 | Acer Aspire 5570-2758 Notebook
Reinstallin acer aspire 5570 orbicam
go into control panal select networking and sharing folder open it look threw all options, defualt program open look threw the fold that you want to change and what programs you want use if the future for web cam optionings.
Jan 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Prolem in orbicam
download the driver and application for orbicam from www.acerpanam.com
Feb 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Orbicam
can you clearly explain me
Feb 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
