Toshiba CX35D80 TV shuts down after a few seconds of operation. If power is turned off for about 15 seconds, TV restarts, but again lasts only a few seconds.
  • 1925 Jul 16, 2008
    Toshiba CX35D80 TV shuts down after a few seconds of normal operation.
    Master:
  • 726 Answers
Yes sounds like a power supply problem maybe is faulty or just had it you will have to get a tech to look at it beaware its dangerious to do it ur self hi voltage inside the box
Posted on Jul 16, 2008
  • 2,427 Answers
The tv is shutting of cause of a safty feature built into the system that when something is wrong it will shut it self off,,
If you are getting picture and sound, chances are its overheating. you will need to open it and look for the heat sinks, touch one at a time to see which is hot. It can be that one of the ic's attached are damaged or not attached propperly.
This is just speculative you will actually need to check it as described above to make sure
Posted on Jul 14, 2008
  • 689 Answers
Faulty power supply unit causes the issue. Best thing the have hands on diagnostic. Check the DC voltages
  • ExpressFiX
    ExpressFiX Jul 14, 2008
    Also overheating another possibility, If you unplug the TV about few hours it might gets better. at least it will last longer.
  • ExpressFiX
    Please let me know if you If power light creates certain code after it turns off. So it will give us better understanding the issue
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
Manual restart
I assume you have no mouse pointer.
Try pushing the Control/Alt/deletekeys all at once twice to see if that restarts it.
If not, push and hold the power button till it shuts down.
If it doesn't fully restart, then you may have to start it in safe mode. (this is ususlly done by tapping the F8 key as it is starting up)
Let me know how it goes.
Oh, Some of the reset button holes are only small enough for a small paperclip to go into. SO these are sometimes hard to find.
Fran
Oct 21, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Mio digi walker 220
I had that error and when I did a restart (hold in the power button for 10-15 seconds to turn off then again for 10-15 seconds to turn on) the unit restarted fine. Try that.
Mar 01, 2008 | Eagle IntelliMap 500C GPS Receiver
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
