Question about Brother IntelliFax-4100e Fax
Error 11...what does it mean?
We have a Brother Intellifax 4100e. We received message of error 11, what it mean?
  • 561 Answers
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Posted on Jan 10, 2010
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
My brother intellifax 4100e is not recieving faxes we can send and I called the fax it works and we can copy but cant recieve.
Does the machine actually answer the incoming call? If so does it give an error code? Are you using the genuine brother line lead? Finally make sure the line lead is plugged into the "line" socket and not the "tel" socket.
Aug 15, 2011 | Brother IntelliFax-4100e Fax
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e There is a message on the screen to change drum, and I already changed it. Also, there is a squeggy noize everytime we receive a fax. I tried taking the drum, carthridge and I...
1. Open the front cover and then
press Clear.
2. Press 1 to reset.
However, the drum may be defective and causing the noise. Try a different one if you can.
Nov 16, 2010 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
Error 77
Jul 14, 2009 | Brother IntelliFax-4100e Fax
Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Aug 12, 2008 | Brother IntelliFax-4100e Fax
Brother intellifax 4100e
Hi, the error code refers to the heater thermistor short circuited or heater thermistor disconnected or broke when the power was turned on, front cover is open or closed or when the machine exits from sleep mode.I hope this help!!
Dec 04, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-4100e Fax Logo
215 people viewed this question
James Cagle
James Cagle
Jim Keysor
