Question about Samsung SGH-D900 Cellular Phone
D900 Charging problems
Having had no charging problems at all for the first 18 months since I acquired it, my Samsung D900 now runs down within hours after I have just fully charged it. If I charge it last thing at night, the pghone is dead by the time I get up in the morning. This has consistently happened over the last few days. Can u help?
  • 4 more comments
  • Anonymous Jan 02, 2009
    Stesso problema! effettivamente legato al BT!!! Sembra che si blocchi e quindi è come se fosse sempre attivo!!!
  • Anonymous Jan 04, 2009
    same as above and i can't turn my bluetooth off. the phone just crashes when i try and i have to remove the battery to reset it
  • vijay_009 Jan 04, 2009
    iam also having the same problem of charging and if i captured one photo it will be dull when it compare to while iam seeing before capturing
    My samsung d 900 is overheating when beeing charged and when i turn him on after 3 hours of charging the phone shuts down after about 30 seconds
    I tried with other bateery and charger but it is the same
    Can anyone help me
  • apo99 Jan 06, 2009
    I am fighting with the same for a long time. At first I can't turn off my bluetooth. So I set the phone to the original adjustment. But it doesn't help.
    My phone works 3, 4, or 5 weeks normal, the charge stays 4-5 days. Than, suddenly, the battery is empty after 3 hours. Again some weeks with the short running time and suddenly again, the battery ist normal. So I observe it for a half year and more, nobody had and has a solution.
  • Rian Wouters Feb 19, 2009
    I also have the problem my phone does not charge anymore.
    I found out that the pins in the charging connector are completely garbled. I can't fix the connector. However, I saw that a new connector is ridiculously expensive (like 50$), apart from the time and risk to change it and the tools needed.
    Any ideas?
    Problem Solver:
  • 8 Answers
Try a new battery as it sounds to me like your battery is overcharged,if this does not resolve your situation then it is a slightly more complex hardware failure, which is a chip on the mother board of your mobile phone which is called a power ic, this needs to be replaced.for any hardware or software solutions email me at kas-anjum@hotmail.co.uk
Posted on Feb 17, 2009
    Sniper:
  • 56 Answers
Hi there, please check if your blue tooth can activate, if it cannot, your phone needs to be repaired. This is a common problem on these phones.
Posted on Jul 16, 2008
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Samsung d900 . battery run on half an hour during call and if it is sleep mode then till 4 hours only
Please check the adapter voltage and the charging of the battery when placed for full charging. Once the charging has confirmed to be full remove and try once again to see if the phone indicates. Now clean the terminals and connect. If the battery does not last , it is possible that it must be replaced. Please confirm with a battery from a friend and buy ONLY the original with warranty.
Apr 26, 2011 | Samsung SGH-D900 Cellular Phone
No display, but i am able to receive incoming calls. Can I get a spare display unit?... Thanks in advance. My model no. is SGH-D900
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 10, 2010 | Samsung SGH-D900 Cellular Phone
My phone samsung d900 is charging up witout charger installed
The charging port on your D900 may be broken. Have you tried a different charger first?
You have 3 options when the charge port breaks.
1. get it repaired, under warranty if possible
2. Get a new D900
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on Ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Jun 03, 2009 | Samsung SGH-D900 Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
D900 won't turn on , But battery is ok
Your charging port may have broken. I am seeing more and more of this type of problem. Did you try a different charger? If it is the charge port, You have 3 options when the charge port breaks.
1. Get it repaired, under Warranty if possible. About 60 dollars
2. Get a new one, runs sbout 75 dollars
Samsung SGH-D900 not charging problem repairs
Apr 20, 2009 | Samsung SGH-D900 Cellular Phone
No charge
It very well could be the charging port. As for getting samsung to repair for free, willnot happen. As long as it lasted through the warranty period they are satisfied with the design
With a bad charge port, You have 3 options.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
Samsung SGH-D900 Broken Charging Port Repair
Jul 24, 2008 | Samsung SGH-D900 Cellular Phone
Problem charging D 900 and opening sim folder
The charging port on your d900 may be broken.
2. Get a new one
Jul 14, 2008 | Samsung SGH-D900 Cellular Phone
D900 samsung
then you should take the phone to a mobile service center and have the firmware reflash on the phone.
May 27, 2008 | Samsung SGH-D900 Cellular Phone
Sansung d900 wont work
Take The Battery Out,Give It A Wipe Inside,Take The SIM Out And The Put It All In A Again And See If It Works.
Otherwise See If It Can Be Repaired By Warrenty?
Good Luck :)
Regards,
Sophiee.
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
124 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
