Computer beeps when I try to move to mouse - Computers & Internet
  • jgruss9078 Jul 14, 2008
    Thanks...I'll give it a try.
    Sergeant:
    Champion:
  • 327 Answers
New mouse or old ? if new remove it and try to plug it back in computer should tel you new hardware found if not then try to make sure the mouse is plug in if it is look at the plug closely and see if any of the prongs are bent if they are you need a new mouse .....if none of this is the problem try a different mouse if it work the other mouse can not be used on your computer with out the right drivers
Posted on Jul 14, 2008
MMy mouse will sometimes move to corner of screen and beep. What might be causing this?
I would try replacing the mouse first, you can buy generic ones on eBay real cheap.
May 11, 2017 | Computers & Internet
Computer is stuck in power save mode. I have shut it off, on, pressed keys, and moved the mouse. It beeps 6 times and then won't come up.
What is the make and model of your computer? There are so many out there, it is hard to figure out your exact problem. Also - are the 6 beeps all at the same time, or are there any pauses in between them (i.e. 1 - 1 - 2)? If you can provide this information, perhaps we can find a solution for you.
May 11, 2015 | Dell Computers & Internet
My cursor on my eisystem laptop is stuck in one place and wont move tried restarting but doesnt help .thank you
try moving the usb mouse to another port - you should hear it beep its disconenct and reconnect. if the mouse is ps2 then you need to power off before reseating it.
if you are using a 'ball' mouse, then you may need to clean the mouse ball and rollers of the build of of ****. if its an optial mouse and the led isn't lit, then you may need to replace your mouse.
Feb 26, 2011 | Computers & Internet
Computer won't boot up. It beeps 7 times over and over.
hi
beep is a problem with your hardware. Check your hardware one by one
thanks and regards
Dec 08, 2010 | Dell Inspiron 530s Desktop Computer
My computer is making a buzzing sound...
sticky key might cause the problem and make your system hang up, try to check/replace keyboard and or your mouse,running low memory is another cause of beep, are you running more than one program that time?pop ups can cause beep too,is that helps?...
Aug 30, 2009 | HP Compaq Presario SR1950NX PC Desktop
Keyboard beeps when any key is pressed
The reason these beeps are happening is because there might be a key that is slightly depressed enough to where its registering keystrokes. Move your fingers all over the keyboard and see if you the beeps stop after you do that. If it still is going on then that means your keyboard is bad and will need to be replaced.
May 28, 2009 | Gateway 2520915 Keyboard
Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Feb 01, 2009 | Dell Dimension 4700 PC Desktop
My computer beeps when I try to move to mouse at the start up screen.
dear,
check that mouse with the other system. if the status remains the same then its mouse problem. if it doesnt do that then the port of mouse (if it is serial or ps2) creating the problem. so check it out.
Jul 14, 2008 | Computers & Internet
Beeping from motherboard
ladysharm,
Make sure that all of the plugs are plugged into the right places. Mouse ,Keyboard,etc..How does it beep? 1 time 2 times??
please post any beeps codes.
Feb 26, 2008 | Packard Bell (181379) Motherboard
Monitor not receiving data from computer?
If you did not hear any beep from your CPU, then the problem is in the system not the screen.
Try connecting the screen to another computer and try also a working screen of a friend to your computer...
You'll find out that either the screen or the computer...
Good luck... post me back for your result.
Don't forget to rate too.
Thanks...
Jan 29, 2008 | Dell E176FP 17" LCD Monitor
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
