Question about Canon ZR500 Mini DV Digital Camcorder
Canon zr500 Can you please tell me what i need (software,firewire cable,etc.) to transfer video from my canon zr500 camcorder to my pc.Thanks for any help,don't know alot about this..
  • Anonymous Apr 20, 2009
The ZR500 has a firewire port that is best for tranferring video to your pc, so a firewire cable would be needed -- and you would need a firewire card in your pc to accept it. It might also have a USB port (don't have it in front of me right now). I've never used USB to transfer video, but I think it would work fine.
Posted on Oct 08, 2008
Can get mt canon zr500 camcorder to get reccognized on my laptop.. i have windows vista on my laptop...i'm trying to transfer my mini dv tapes on my canon zr500 to my computer..what do i have to do?
You have to use a firewire connection in order to transfer your videos. The cambera will not transfer the videos through the usb ports. There is no specific driver for Vista, and this isn't a driver issue. Use your firewire port and cable, and you should be fine.
Good luck,and hope this helps.
Mar 19, 2011 | Canon ZR500 Mini DV Digital Camcorder
What do i need to connect my canon zr500 camcorder to my pc?
IF, your camcorder has FIREWIRE, than you can use that, and suitable DVR software. IF not, then I always recommend that, one use a TV/Video "Capture" card or USB "Dongle", either way, you simply connect that up, via, the AV, leads, usually S-VHS, or Composite, Or Component, or Firewire, Use a DVR, and basically, "Play" the "Video" and "Record" on the PC, with Digital Video Recorder, DVR, and save as a "Digital Format" then you can do whatever you wish, after recording. You can get propretory software from the manufacturers website, and download, drivers, and software to do as you wish. I recommend a program called Dscaler, it is the BEST DVR there is.
Apr 28, 2010 | Canon ZR500 Mini DV Digital Camcorder
FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Aug 21, 2009 | Canon ZR500 Mini DV Digital Camcorder
I need to import video from my canon zr500 to my pc
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | Canon ZR500 Mini DV Digital Camcorder
Hi!
You can import videos from your camcorder to your PC using a DV cable. Check this page from the user guide of your camcorder.
Basically, you need a firewire port and a DV cable. Most computers (new ones) already have firewire ports (or 1394 ports).
I hope that helps.
Good luck and have a nice day!
Nov 22, 2008 | Canon ZR500 Mini DV Digital Camcorder
About transfering video from the tape into PC
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Yes, it is something to do with Firewire. I managed to dothis with my Canon MV750i so I know it can be done!
You are correct; the USB cable only transfers pictures from the SD card. To transfer video from your camcorder to a computer you need to use a Firewirecable (also known as IEEE 1394), and you need to have a socket on your computerto plug the Firewire cable into. Macs already have a socket built in butgenerally with PCs you will need to install (or get someone to install for you)a special card with the Firewire socket on it.
I can't explain the whole procedure here but you can getstarted by looking at the following articles on the Canon website. Thefirst one explains what sort of connections can be made on different Canoncamcorders (including the MV730i) and what you can do with them:
http://www.canon.co.nz/products/digital_video_cameras/home/mv730i.aspx
The second briefly explains what hardware and software youwill need, how it goes together, how to make DVDs and so on:
http://www.canon.co.nz/support/customer/default.asp?DXI=KnowledgeBase/Customer/KBArticleForm&File=KB01213&productID=mv730i
Unfortunately there is no quick, simple answer but I hope thispoints you in the right direction!
Sep 25, 2008 | Canon MV650i Mini DV Digital Camcorder
Hi, You do need a firewire cable (which is normally provided with the camera) and a firewire port in your computer in order to get images off the tape which you have recorded onto.  The card however can be accessed via USB.  The card can store video as well as pictures although if it is the card that you bought the camera with it probably has very low memory. If I were you I would take one of these two solutions
  • Buy a firewire cable and a firewire PSI card for your computer.  Use an editing software eg. Pinnacle or Windows movie maker to import video files from camera.
  • On the camera above the power switch (camera, OFF, play), there will be a switch which at present is down indicating to video.  Switch it up to card.  This will then record video to your card which you can load to your computer same as the pictures.  You might need to buy a new SD card (located in compartment -Multi Media Card- next to lcd screen.) these can be quite cheap and 1 GB can hold more than an hour of footage.
Hope this helps- Any more questions just ask
Jul 10, 2008 | Canon MV730i Mini DV Digital Camcorder
No driver for Canon FV M200 camcoder
Are you connecting to the camera with a USB cable? Many camcorders will not allow you to transfer video over the USB interface. Video transfer often requires a Firewire connection and software. You'll need a Firewire cable (sometimes called a DV cable).
If you computer is reasonably new it most likely will have a Firewire port. If not, you'll need to install a Firewire PCI card.
The software I use is called Scenalyzer. There are other options, but Scenalyzer has a free demo you can try. You can download the software here:
http://www.scenalyzer.com/
The demo software is fully functional, but it will leave a watermark on your video.
Good luck.
Dec 09, 2007 | Canon MV700 Mini DV Digital Camcorder
JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon ZR500 Mini DV Digital Camcorder Logo
699 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
