Question about Frigidaire Washing Machines
I have a GLTF1670AS Front Load Waher that recently has started to collect some water in the drum while not in use. What can be the cause of that?
  • 41 Answers
Faulty water inlet valve passing water while de energised
Posted on Jul 14, 2008
Why does my LG VM2701HV front load waher not spin out. The spin light flashes and motor hums but the drum doesn't move??
The most likely problem is the capacitor on the motor, the capacitor charges up to a higher voltage, as the inductive load (the motor) needs more power to start up, the capacitor releases n burst of higher voltage to start the motor, so replace the capacitor, and the chances are 99.9% that your problem will be solved
Oct 03, 2017 | LG Washing Machines
Water is collecting in the drum in between washes . Do we need a new inlet valv? Also, is there a different inlet valv for hot and cold?
1 for hot 1 cold//Water in the drum is it pumping out ok?...could also be drain hose too low taking purgeback from sink drain. raise this to cure...
Nov 12, 2009 | Tecnik TKL9260 Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Drum speed slow on final spin
what waher is this and what speed is it
Dec 05, 2008 | Kenmore 46462 Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frididair GLTF1670AS Front loader washer problem-water will not run in
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
Nov 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
