Question about Nintendo DS Lite Console
Startup NDS lite tune
Hi all, im getting a really odd nds lite startup tune. Its higher pitched than the normal starting up sound. I doubt its the actual speakers though, since it plays game sounds perfectly. Does anyone have this same problem? Thanks
It's your Birthday! Happy birthday! or not..
Posted on Aug 15, 2008
The startup sound is different on ur birthday
Posted on Jul 29, 2008
  • 61 Answers
It still might be the speaker, most games are on the low sound spectrum, but the start up tone is a very high pitch, speaker might have a tiny hole in it.
Posted on Jul 18, 2008
Hi Their is an error that comes on my ds lite it come when i play on the r4 . it says...
What i will do is try and run nds mood, and if not.
OR
Remove the battery cover using a screw driver and hit the reset button.
Mar 03, 2011 | Nintendo DS Lite Console
After install woods r4 my nds formats by startup the card leaving an unreadble 2gb card behind
Hey there,
Try using the original R4 firmware instead of R4 Wood (check out nintendodscards.com for the download page, the original firmware should be around there) or buying a newer genuine card from either dscardworld.com or nds-gear.com - both sell real cards but nds-gear has better shipping rates to Canada and Europe. Good luck!
May 12, 2010 | Nintendo DS Lite Console
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
How do I unzip a .nds file and a .war file before
You can not really unzip a .nds file as that its the game file itself. That's the format of the DS games.
Feb 01, 2010 | Nintendo DS Lite Console
R4 SDHC Upgrade gives error "MENU?" on startup.
Are you download real programs for R4? Go to www.r4ds.com to download it,it will better because i download it at there too and it can play
Jan 23, 2010 | Video Game Consoles & Games
My NDS lite power cannot be turned on and turns off randomly
The problem is that your son dropped it. This damages both the inside and outside of the DS. I would suggest contacting your nearest video game store to see if they can fix it.
Aug 04, 2009 | Nintendo DS Lite Console
On gta chinatown wars it says save data cannot be acsesed please turn he ds off and reinsert the ds card
patch GTA using dslazy.
Small gui to some NDS utilities.
- get nds file info using ndstool.exe
- append a file to ndsloader.bin
- apply ndspatcher.exe to a nds
- grep for bricker code in .nds
- trim blank space out of a rom
- unpack and repack a nds using ndstool
extract to somewhere eg C:/ds/dslazy
run dslazy.exe
select a nds file(which is GTA right?) by hitting the "..." button.
get the rom info by clicking the [?]
hit the desired patch button
select where you want the new file to be if appropriate..
Unpack the said nds file(GTA)
search ARM7 download on Google, and DL it
then paste it on the unpack nds files which is on your ds lazy folder "NDS_UNPACK folder" overwrite if ask. Then repack it save the repack nds file wherever you want and your done copy the patch GTA on your SD card. If you don't get it try searching ARM7 patching on google.
Jun 12, 2009 | Nintendo DS Lite Console
DS Lite will not power on
blowin F1 or F2 fuse or both inside your nds. can be fixed by runnung a bead of solder the blown fuse so it bridges the fuse (idealy you would replace fuse but its very tricky) first of all if you have a multi meter check the fuses before soldering them. anyway i advise not to use the homebrew card especially on your nds when you bridge the fuses as once the fuses have been bridged there is no saftey shut off to stop more sever damage. oh by the way just youtube F1 and F2 fuse location to find out where they are. oh and use a 15watt solder iron to be on safe side (less chance of overheating any components near fuses when soldering). its not that hard to do really (i did 2 of them with a gas solder iron due to me not having a 15watt iron) also replaced cracked screens. my next job to do is replace a L2 inductor on a friends nds (symptom for this fault is nds charges but will not power up, not even a blink of green light) for anyone who has this symptom its the L2 inductor thats broken away
Mar 28, 2009 | Nintendo DS Lite Console
R4DS
what is R4DS?
Dec 26, 2007 | Nintendo DS Console
Wifi NDS problem
Look for guides like these ones here:
Nintendo Wi-Fi Connection Instruction Booklet
Or this one:
Set your Nintendo's Wi-Fi Connection
Try this and let us know. Good Luck...
Nov 29, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
184 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
