Question about Nintendo DS Lite Console
Left side of the screen not responding - Nintendo DS Lite Console
  • Anonymous Feb 17, 2009
    My ds lite touch screen does not work a well as it should...... what should i do ?
If there is a grain of sand or other item stuck between the touch screen (lower) and the frame of the unit, this will cause the item to appear to be locked up. Apply a little pressure on the touch screen where it meets the frame on all four sides to allow any debris to fall out of the unit. You will have to do this four times, once for each side holding that section up so that the debris will fall down and away from the unit. Lots of luck. It worked for me.
Harry
Posted on Mar 23, 2009
  • 88 Answers
If you are in the UK I can replace the DS touch screen for £18.99 including next day special delivery,
Contact sir71fon@gmail.com for details or visit me on ebay, username ynysmon2007
Posted on Jan 30, 2009
  • 34 Answers
  • Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
  • Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
  • If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing the POWER button.
    3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
    5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
    6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
      • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
      • If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
      • If the above steps did not help, there is a problem with the system and it will need to be repaired.
    7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
    8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
    Posted on Jul 14, 2008
    One side of my nextbook 7 se is non responcive
    Sorry, but this will require a new screen and a new digitizer. Might be cheaper to just buy a new one and put this on ebay to sell as parts/non working.
    Nov 05, 2013 | Nextbook Premium 7 Capacitive Touch...
    Hi, Recently the screen on my garmin 1490t gps cracked near the lower left side. As a result, the unit is no longer responding to touch on the left side. I should note that when I tun on the gps, the...
    I am glad to HELP YOU!
    Definitely after the impact your device became LESS SENSITIVE on the lower left side.
    So as a replacement you will need
    FIRST - the digitizer
    SECOND - the display [but ONLY if the older display has cracks or other damages].
    GOOD LUCK!
    Windows Tips
    Apr 24, 2011 | Garmin nuvi 1490T GPS Receiver
    3110c no display
    hi there!
    hope you can give us more details on what happened before this problem started. but if you dropped the phone, try pressing the lcd screen's left and ride side, top and bottom too, see if the lcd screen responds. if not, it may need replacement. if it does respond, you still need to bring it to a techinician for they need to open it up and check if the lcd ribbon was disconnected or if it indeed need replacement. post back if you have more info for us to resolve the issue!
    Apr 13, 2011 | Nokia 3110 Cellular Phone
    Left touch screen doesnt work & doesnt send a load
    your touchscreen is probably going out. Many of them will fail on one side before the other because the cable that connects the touchscreen to the unit itself will tear or malfunction. you need a new one.
    Jul 23, 2009 | Cell Phones
    Space bar, left-side enter key and backspace do not respond.
    Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
    Jul 21, 2009 | Logitech S 510 (967555) (DH967555)...
    Screen problem
    my a1200 screen doesnt respond anymore wat a waste
    Nov 16, 2007 | Motorola Mobility MING A1200
    Son 1,mom 0
    There may be a reset facility on the TV. Check the back, it will be a very small posh switch, size of ball-=point pen. If available it should restore to factory setting
    Oct 06, 2007 | Sylvania SRT2232S 32" TV
    Avic d1 touch screen issue
    The touch screen calibration is of, the screen has to be changed.Its 200$ from pioneer or you can look on ebay theres a place in ct. that will do it for 125
    Sep 28, 2007 | Pioneer AVIC-D1 Car Video Player
    Nintendo DS Lite Console Logo
    170 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
