Time on DVD/VCR Combo auto resetting
When the clock on the Sylvania MODEL 2V450SL8 hits 12:00am or 12:00pm it auto resets to 9:00am - every time.
Any suggestions on what could be occurring.
It is connected to cable (COMCAST).
  • brian02878 Jul 14, 2008
    not sure yet - won't be able to fix until later this week - thanks for the info!
  • 19,396 Answers
Many model have a timer auto setup function, if it is not this then it is a fault.
I see if I can find more info.
Posted on Jul 14, 2008
  • 2 more comments
  • Ginko
    Ginko Jul 14, 2008
    Darklord1 may be right it can also be the cmos battery gone, the fact is that in this case (battery gone) it should rather reset when you disconnect from power or eventually turn it off, not at a determined time.
  • Ginko
    Ginko Jul 14, 2008
    As I suspected your DVD has Auto Clock settings, CMOS battery probably is not cause for the problem.
    Check you user manual for Auto Clock settings and disable it.
    Here is procedure for a similar model:
    Hit [SETUP].
    Easy Setting Menu or Advanced
    Setting Menu will appear.
    If Advanced Setting Menu is displayed,
    proceed to step 3.
    Using [K / L], select
    “Advanced Setting Menu”.
    Hit [ENTER].
    Advanced Setting Menu will
    appear.
    Using [K / L], select “Clock”.
    Hit [ENTER].
    Clock menu will appear.
    Using [K / L], select “Auto
    Clock Setting”. Hit [ENTER].
    Option window will appear
    5
    Set 'auto' to off.
    Try the procedure, if it works you should change solution rating and accept my solution.
  • Ginko
    Ginko Jul 14, 2008
    If you do not have Sylvania user manual go to Sylvania website and download it, by clicking on support and user manuals.
  • Ginko
    Ginko Jul 14, 2008
    here is website:
    Sylvania
  • 2,427 Answers
Yeah ,, there is a battery located on the mmainboard of the dvd player, YOu';d need to open it up to find it. Its about the size of a penny / quater it looks like a large watch battery,, Simply replace this
  • Rishi Roshan Ali Jul 14, 2008
    Ginko can be right sir you shouldnt have voted Fixya yet.. IF the battery aint the problem then I'd suggest you contact fixya and have the fixya vote rmoved as it would be unfair to ginko or another expert who may have posed the right solution.. But my money is on the battery.
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Clock will not keep time
Aside from resetting the time to the correct time every once in a while, it's not worth fixing. I have a sharp vcr that the clock starts to run fast 2-4 weeks after i set it.
And another thing to check is to make sure the VCR is not plugged into a socket that activates with a wall switch that you might turn on and off everyday.
Apr 10, 2010 | Sylvania 6260VF VCR
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
I cannot reset the clock on my Toshiba 392 DVD and VCR combo
If I remember you will only get the System Setup if the unit is set to DVD only it will not allow this in VCR mode I will need to double check and get back with you
Sep 26, 2008 | Televison & Video
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Clock changes time by itself
If you have a govideo combo please tell me how to set the clock I have no manual.
My problem is directly above yours. Thank you.
Feb 26, 2008 | GoVideo DVR4400 DVD Player/VCR
Sylvaniadvc 865f dvdplayer/vcr cannot get the dvd to play
First try to clean the laser lens with a lens cleaning disc. Next if that doesent work clean it manually
Aug 23, 2006 | Sylvania DVC-865F DVD Player / VCR Combo
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
