Canon gp335 lost manual and trying to figure out how to change the toner cartridge
  • Anonymous Jan 28, 2009
    sos mon copieur gp 335 ne s,allume plus que dois je faire
  • schan68122 Apr 05, 2009
    i just bought a new toner. I place it where the old toner was and the toner light is still on. It will not make copies.
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Technically you add not change toner.
open front door, swing out big black unit, ( toner hopper)
place toner on top of unit with clear plastic piece of toner sticking out, pull plastic tab all the way. When pastic pieace comes off leave for a couple of seconds then push back the black cover of the hopper( came out when pulled plastic piece)
Posted on Jul 15, 2008
I need to change the toner cartridge on a older copier, a Canon 3300i. i can't figure out how to remove the old toner cartridge.
  • Unplug the unit from the source of electricity. Open the front cover located on the face of the unit.
  • Locate the blue lever in front of the toner cartridge. You will be able to see it clearly when you look through the opening originally covered by the front cover.
  • Pull the blue lever down gently. Do not use force. It is easy to manipulate and just needs a gentle pull.4
  • Look for the blue handle that is on the toner box. Grasp the handle firmly and pull it. The toner box will move toward you. Remove the toner box until it cannot go any farther. The handle is easy to manipulate, so do not tug at it, just pull it gently.
    If you will need more help you can download the service manual for ir 3300i is always good to have a service manual you can download it from the below link:
    Good luck
  • Jul 30, 2013 | Canon imageRUNNER 3300i Printer
    Can't figure out how to change te cartridge on a canon imagerunner 3300 copier problem
    Follow the steps below to replace a toner cartridge.
    1.Turn the printer on.
    2.Open cover
    3.Push up the right lever to unlock the toner cartridge.
    4.Remove the toner cartridge from the printer.
    5.Take the new toner cartridge out of its package and gently shake the toner cartridge as shown below.
    6.Hold the tag and gently pull the toner seal upward and remove it.
    7.Insert the cartridge all the way until it stops securely with the arrow mark on the top of the toner cartridge facing
    8.Push down the right lever to lock the toner cartridge.
    Aug 02, 2010 | Office Equipment & Supplies
    My toner was low, so I replaced printed one page and now won't copy or print (cannon multipass mp730)
    If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
    Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
    When you get the no toner message re-insert the new toner cartridge.
    If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
    Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
    Remove toner
    you push in on the front top where the stop strip was and it will pop up unless you have yet to add toner to the developing hoppper then you would fallow the directions on the toner box
    Mar 17, 2010 | Canon ImageRunner 3320N Copier
    Cant find where to change toner on canon dr 3060
    Scanner is just an 'input' device and no toner is required. You need toner/cartridge only for printers/plotter (output devices).
    S. Mohan
    Apr 09, 2009 | Canon DR 3060 Path-Through Scanner
    Rotating toner cartridges to change
    Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
    Apr 08, 2009 | Canon Office Equipment & Supplies
    Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
    There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
    Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
    When we insert the printer cartridge into our canon mf4600 series fax machine it says 'Toner not Set' We have lost the cd and only have it in a foreign language. Can you help as there is no...
    Well, is it a recycled cartridge or a new one? If it is recycledit's possible that the cip if it has one must be replaced! If the cartridge is the original one/it hasn't been changed before you may have a conatact problem with one of the sensors!
    Nov 13, 2008 | Canon Office Equipment & Supplies
    349 people viewed this question
