Question about Motorola Mobility H700 Wireless Headset
Motorola h700 ear piece
The code 0000 is not working to pair my ear piece with my new phone any ideas?????
  • Destini Feb 11, 2009
    I just found a h700 bluetooth and I'm tryna pair it with my sidekick 08' it keeps asking for a passcode. My phone automatically tries 1234 and 0000, are there any other suggestions
    Scholar:
  • 77 Answers
Try 1234....hope this helps...I believe someone else in here tried that code and it worked.
Good Luck
Posted on Jul 15, 2008
  • Thomas Van Tress
    Thomas Van Tress Jul 15, 2008
    Just to be advised though, from the Motorola web site, the default pin code for Motorola bluetooth headsets is 0000 (four zeros) and cannot be changed.
    Hope this helps.
How do i put the motorola h700 in pairing mode
Hi terantra,
I would like to assist you with your Motorola H700 headset, Please see steps below.
  • Make sure that there are no other Bluetooth devices in the area.
  • Now set the device that you want your Motorola H700 to pair with make sure that it is detecting devices.
  • Now on your H700 Motorola press and Hold down the Multifunction Button on it, and open the mouth piece.
  • This should be detected right away by the device that you are pairing the with the H700, the pairing Code for this H700 will "0000"
I hope that his will be of help regarding your concern.
Have a nice day,
mvincent
Apr 22, 2011 | Motorola Mobility H700 Wireless Headset
0000 does not work as a passcode to pair my H700 to my LG phone. I have also tried 1234 and every other combo. What is wrong
The default code is either 0000 or 00000. That is, four or five zeroes.
You can set a new pairing pass code once you connect it to your phone by changing the pairing code from under the connected devices settings in your bluetooth menu.
Jan 27, 2011 | Motorola Mobility H700 Wireless Headset
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
Jul 24, 2009 | Motorola Mobility H700 Wireless Headset
Need generic pass key for H700
open boom on ear piece
turn on bluetooth on phone and go to paired devices
hold button on ear piece till lite turns purple
under paired devices click connect
0000 is the pass key
should work
May 28, 2009 | Motorola Mobility H700 Wireless Headset
H700 bluetooth ear piece - Pairing with new phone
Press and hold the call button while the boom is in the off position for 4 to 5 seconds. The blue indicator light should come on and stay on. The unit is now in pairing mode. Initiate you phones feature of searching for bluetooth devices and pair the two together. The default passcode for the H700 is "0000" four zeros.
Good Luck
Jun 22, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700c
Hey Beckypattie,...try 1234,that is the alt. code for 0000
Dec 23, 2007 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
Pairing
i have a samsung r410 and have the same problem.... im thinkin its the phone....
Oct 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
130 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
