Problem with Canon PIXMA MP210 Photo All-In-One Printer
Canon Printer MP 287 Ink Cartridges
Canon Printer MP 287 Ink Cartridges are full: - Magenta tank shows light off - pressed properly/ light goes off - Alarm light is on, On button light is off, Alarm light stays on - Printer doesn't print.
1,386 people viewed this problem
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
6 Suggested Solutions Relevant solutions from other related problems that we feel might be a fix.
Author image
Go to this link. Type "error e 2 3" in the search window and click the Search button. Try the troubleshooting steps provided. If the error still persists, you may need to have the machine serviced.
Source: giving the error e 2,3
  • Was this solution helpful? Yes No
Author image
  • JM Alvis
  • 164 Solutions
  • February 08, 2010
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Source: Canon MP610 Brand new ink cartridges installed,
Author image
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Source: MY Canon Pixma MP 500 Printer won't Print.
Author image
I just had the error message V130 - check ink cartridge. I held down the stop/reset button for about 5-10 seconds and the problem was solved!
Source: Alarm light on, Display indicates error message: Check Ink U150 M
Author image
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Source: Magenta printing as yellow
Add your solution
Full Name
Top Canon Printers & Copiers Experts
CameraR
  • Solutions: 4713
  • Level: 3
  • Achievements: 4
Ty Price
  • Solutions: 11967
  • Level: 3
  • Achievements: 1
K_akima
  • Solutions: 43343
  • Level: 3
  • Achievements: 6
Expert Badge
Are you a Canon Printer and Copier Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More PIXMA MP210 Photo All-In-One Printer Related Problems
Unsolved Problems:
See all Canon PIXMA MP210 Photo All-In-One Printer Problems
Loading... Loading...
