Question about HP LaserJet 3050 All-In-One Printer
No paper pick up
The printer was working great until last Thursday and it just stopped and came up with the error message...... no paper pick up, press (check mark). I have done this a number of times plus I have unpluged and re-pluged again and still nothing. The green ready light also does not come on. What can I do as I desperately need the printer for my job.
Thank you
Rose Mary
  • 21mel Sep 23, 2008
    1. no paper pick up
  1. send me immedietely
Posted on Sep 23, 2008
I have an officejet 5610 all-in-one inkjet printer. There is an ornage exclamation mark next to the setup between the pound sign and the setup button that keeps blinking. How do I get it to quit. I...
The Exclamation mark is an Attention: error indicator. There is a problem that you need to fix. You need to fix the problem. Was there is any message on the LCD screen when you started having the error?
Press Cancel and try printing again since you apparently cleared the LCD message. The problem could be a paper jam, no paper in the paper tray (or the printer can't pick up the paper), an ink issue or something else.
Please add a comment with the error message for additional support. I need more information to tell you what steps are most likely to solve your problem.
Apr 19, 2012 | HP Officejet 5610v All-In-One InkJet...
My son-in-law is a computer and cash register repairman. He checked my printer out and thinks that I have a bad charging device problem. Black print works great, but colors just will not work. Blue toner...
The error code 10.0002 is a problem with the magenta cartridge. To be precise it is a e-label error.
The e-label is a small circuit board on each of the cartridges.
Pull the magenta cartridge and clean it.
Now as to the ETB (that's the big mylar sheet with the cyan toner all over it). Get rid of the cyan cartridge, it's obviously dumping toner. Remove all the cartridges and the ETB, and vacuum out the printer...with power off.
Power the printer on and when it comes ready
1. press the select button(check mark)
2. press the - and the 'cancel job' button together (at the same time). release both
3. press the select button. You now should be in the 'secondary menu'.
4. press either left or right arrow buttons to navigate.
5. navigate to CLEAN ETB
6. press select(check mark) and let the machine do its' thing.
Good Luck
Do get rid of the cyan and probably the magenta.
Feb 15, 2011 | HP Color LaserJet 2600n Printer
Hello, I have a canon pixma printer iP1500 and it has been working fine until yesterday. I keep getting a paper jam message but no paper is stuck. Then the paper will go in off sided and the paper does...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 30, 2010 | Canon Office Equipment & Supplies
Hi Our printer fax has just stopped pulling the paper through and says there is a paper jam but we cant see anything in there. I rang lexmark and they said to take everything out and shake it gently upside...
Nov 30, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
C4180 HP PRINTER GIVING ME AN ERROR MESSAGE OF "CLEAR PAPER JAM , THEN PRESS OK." THERE IS NO PAPER JAM.
Aug 18, 2010 | Office Equipment & Supplies
When we send any file to print it is giving load manual feeder error
This will set up your printer for plain letter paper and should relieve the manual feed error unless your computer is sending other paper size/type settings.
Aug 09, 2010 | Lexmark X364dn All-In-One Laser Printer
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
