Question about Gateway Computers & Internet
My Dvdrw driver drive dissapeared off my pc and is nowheres to be found, how can I re-install it ?
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
In windows you generally do not require to install drivers for things like optical drives. It sounds like maybe the power or data cable inside the computer has came loose.
So you would need to either check the insides the computer (with the power off) to make sure the power and data are connected. You will see below the pictures of each type of cable, so you can check the DVD is plugged in.
This is a picture of the back of the DVD drive, notice the 2 cables plugged in. These are the cables you need to check are plugged in. Once you verify these are plugged in, turn on the computer and watch for any errors, then hopefully the drive should just re-appear.
Hope this helps.
Posted on Jul 14, 2008
  • Gateway Master
  • 19,396 Answers
Try first restarting Windows.
  • Ginko
    Ginko Jul 14, 2008
    There is nothing to re install, dvd units (including DVD RW) do not need drivers, and normally they are automatically recognized and controlled by Windows through BIOS, with no need for additional drivers.
    Sometimes Windows may lose control on some of the drives, and the undetected drive will not be displayed in my computer.
    Often you solve this just restarting computer.
    On some BIOS a disk drive autodetect can also help fixing it.
    If the drive still does not appear, then you fix this either reinstalling Windows, when it is a system problem, or replacing driver or checking/replacing connection cable if it is hardware problem.
  • Ginko
    Ginko Jul 14, 2008
    Note : If you touched your computer hardware before this happened,for example replacing a drive, then it is likely to be a problem with connectors or Slave/Master settings.
My mobile broadband manager say "device not found" help
You need to update your device driver and you can do this by downloading the latest driver from manufacturer`s website and then re-install it.
Oct 29, 2013 | Dell VOSTRO 3300 I3350M 226G 2GB 250GB...
Aspire 4520 lost cd-dvdrw drive off my laptop nowhere to be found, help
Hi
You could go to
www.acer.com
find your model and operating system
scroll down to find the cd/dvdrw driver
download it
install it
and restart laptop
this may re install your drive
Jul 23, 2011 | Acer Aspire One PC Notebook
I installed the new cd/dvd driver, but the compter won't install it.
If this is the only drive on your PC you have to make sure that you have set up the jumper to master. the jumper is located in the back of the drive. you must also install the driver for the drive to work properly.
Feb 28, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
I have recently purchased ACER AMD desktop & now I M facing problem like when I am installing windows 7 cd it reflects like hard disk not found
There is possibly either a non initialised drive in the bay, the drive is not set as master and other problems.
Does the BIOS see the drive and does it know what its size is?
If it does, then the PC will load the required drivers and OS to format the hard drive and place a system on it.
Try again
Jan 05, 2011 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
My Brandnew Toshiba L305 doesnt detect my DVD drive
go to device manager in control panel,system.
select the cd/dvd drive,right click it, bottom offer,un-install.un-install it.
reboot.
should be good.
Regards
Richard.
Apr 22, 2009 | Toshiba Satellite L305-S5894 Notebook
Doesn't show as a driver
I did it!...
you have to perform all the windows updates, then you have to install "Windows media player 10" (I have installed "Windows media player 11" because on my pc the wmp10 didn't work...).
it seems that YP-Q1 work with some driver hidden in wmp10 or 11...I didn't found them nowhere...
connect the mp3 with the cable usb and test to automatically install the drive... it should work... I did it after a few hours...
sorry for my dumb-english, I must improve it ;)
Dec 25, 2008 | Samsung Audio Players & Recorders
DVD-RW Drive not working with all media types
might be a driver problem. when you say it wont run, do you mean it doesnt automatically start? or it wont start if you go to mycomputer and click on the drive and start it from there?
first follow this link and follow it to the driver for your dvdrw, download and install and see if that works
if this diesnt work please let me know and i'll assist you further
Dec 25, 2008 | Dell INSPIRON 6000 CENTRINO...
Dvd rw drive not reading discs (DVD and CD)
That sound to me like a defective dvdrw because it can't read the dvd an try to re read and re read and lock the computer until you take it out.
Solution:
Tools:
+ Small screwdriver
-- Small screwdriver
Buy a new or used dvdrw for laptop, first take out the laptop battery. Locate the two screws at bottom of your laptop, take them out, whit a paper clip open the dvdrw from a small hole in front of it, pull the defective dvdrw out, if the front plastic face plate is diferent from yours you can change them using a small - screwdriver (be carefull). If you dvdrw have a smalls canals at sides in your defective dvdrw take them out and put them in the new one two, Install the new dvdrw by slowly pushing in to the dvdrw hole until it take its place, put the two screw drivers back + the battery and you shuold be on your way. Let us know. Obed
Sep 05, 2008 | Computers & Internet
Ethernet drivers
Most drivers can be found at Drivers.com.
Jun 17, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Computers & Internet Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
