Question about Fuji FinePix S5700 Digital Camera
Numbering of pictures
After clearing the memory card the numbers of the new pictures start again at 0001,00002 etc . How can I get all pictures to be numbered consecutivly ad infinitum.
Go to cam set up menu where you have a choice of image sequence numbering. select continuous and exit from the menu.
Posted on Oct 16, 2008
What is frame number reset on my sanyo vpc-s1085. I read the manual and the answer is vague. what is it for do I cancel or execute? I'm also trying to find out how to let the numbers for the...
If you decide to reset the numbers, your camera will start numbering the new pictures from 000 all over again. This can cause problems when you try to download because your computer will think you've already downloaded pics with those numbers. Don't reset....your camera will continue to number the pics consecutively even after you download and empty the card.
Aug 17, 2011 | Sanyo VPC-S1080 Digital Camera
Clearing the screen
on pressing the menu button the options screen will appear..
on pressing it again it ll disappear
Jun 14, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Memory card filled and I took more pictures. Seemed to put those on the internal memory. What happened too or how can I recover the memory card pictures?
Probably one of two solutions.
First, the memory card should have all the pictures intact. If you are using the camera to review, you may need to just keep going back until the memory card photos show.
Another possibility is that the internal memory supersedes viewing the card memories. You may have to run a USB cable to your computer, download the internal memory photos, and then you can possibly see (on the camera) the memory card photos. It might be a good idea to download those photos to your computer too, if the computer has a memory card slot. Otherwise you will have to go through them and download via the USB again. Once you know the photos are saved, you can either change cards with a new one , or clear the old card and start again.
Good Luck
Mar 04, 2011 | Nikon COOLPIX L18 Digital Camera
How can i change number of pictures i can take
Your camera has only 10 MB available for picture storage using internal memory. An SD card of even 1 GB (tiny by today's standards) will hold 100x as many picture as your internal memory. If you already have an SD card,
1) Buy a larger memory card. These don't cost much and an 8, 16, or 32 GB card can hold a LOT of pictures.
If you want to increase the number of pictures you can store either with the current card or using internal memory, then you have a couple of other options. 1) change the picture size. Menu -> then up/down arrows to select Picture Size. Press the OK button. Select the option you want (6.1 MP, 5.4 MP, etc). Press the OK button.
Feb 26, 2011 | Kodak EasyShare C633 Digital Camera
I take a lot of pictures and delete the off of my SD card. When placing pictures in folders it seems to have the same numbers and this causes a problem with maybe deleting old pics. Is there a way for the...
You have three choices for file numbering, controlled by Custom Setting #D7:
Off: File numbers are always started at 0001 whenever a new folder is created, when the memory card is formatted, or a new memory card is inserted into the camera.
On: File numbers are incremented until they reach 9999, at which point a new folder is created and the file numbering will again begin at 0001.
Reset: The file number is reset to one more than the current number in the current folder. If there are no pictures in the current folder, the number is reset to 0001.
Because the numbering only uses four digits, numbers are going to repeat every ten thousand pictures no matter what you do.
Mar 03, 2010 | Nikon DSLR D90 Digital Camera
Picture contains fragments of other pictures
An update for fellow readers.. After reading few other posts and googling a bit, I was sure that I've got non-authentic memory card.. I tried and inserted a new genuine memory card and all the problems seems to have vanished (for now :)).. I'll keep you posted if the problem appears again.. To find out if your sony memory card is genuine or not, read these guidelines from ebay..http://reviews.ebay.co.uk/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001535763
Hope this helps..
Aug 28, 2009 | Sony Cyber-Shot DSC-T5 Digital Camera
How can i make the picture number continuous with my nikon D2H?
If you go into the menu settings you can choose wheather to let it run on and reset at 9999 or start again or name the new file.
Jan 27, 2009 | Nikon D2H Set Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Reset Folder No.
Finally, I have contacted the Panasonic Repair Centre. The answer is the only way to reset the folder no is to bring it back to the repair centre and have it rested there. Moreover, say there is a file 1000001 in the memory card now. After you use the "No. Reset" function and if you do not format the memory card (in other words, the 1000001 file is still in the card), the new file no will become 1010001 when you take a new picture with this memory card. Therefore, I will format the memory card before I use the "No. Reset" fuction in order to make the new picture started from 1000001.
Sep 13, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Fuji FinePix S5700 Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
