Canon PIXMA MP760 All-In-One InkJet Printer Logo
Donald Roper Posted on Jul 14, 2008
Red mist on both black and white and colour prints
Scanned black and white photos are printed as sepia colour photos have a red caste over them.I have replaced all three colour inks.
  • kathiec Jul 31, 2008
    There is a reddish cast to most everything (seeming to bleed from edges of the image.. Green color prints orange; blue color prints pink, maroon color prints blotchy. The black and white button works fine.
    I have run all of the maintenance programs. The nozzle check looks okay except that the colors are a bit faded. No ink tanks are less than half full.
A
Anonymous
Remove printer driver. and reinstall its driver.
Why are my prints only printing the reds and blues in photos?
Please next time put the question in the correct category. I still will try to help you.
If your printer does not tell you any cartridge is empty, and it still does not use that colour it could be the nozzles of one cartridge are blocked. Check this by printing a test page, as told in the user manual. Sometimes called an alignment print.
Then check if all colours appear correct. Looks like yellow is not working correct.
1helpful
My black and white photos will only print out in sepia. I have plenty of ink in the Cartridges of my MP610. Please help?
Two possibilities come to mind:
  1. There is a function in many printers that lets you print in the single colour of your choice. Check every tab and every "advanced..." dialog box you get when you are about to print. Then go to the printer's properties in the control panel and check whether there's anything like that
  2. Many printers let you print black with black ink, OR alternatively make black by mixing the other three colours CMY. Look for that setting in the same places and deactivate it
2helpful
Doesn't print black and white but prints sepia instead
hi, when you are on printing preference, go to colour click print on grayscale click on the drop down arrow that has high quality and click on black ink only
2answers
Green tinged photos on photo paper normal color output on plain
Assuming a 2 cartridge system, and you want B&W or sepia, pull the color cartridge and print away! Works for my HP DJ 5440.
1helpful
I have a Canon MP610 printer.The Test page prints ok.The copy fuction is perfect co;our and black and white.When printing from a file saved on computer the text has a sepia tone not black and white....
just chk the properties or the colour cobinations if you choose text for printing out than it will only print text and if it is too dark red that means it is connected with some wrong colour wire
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Red cast on all prints
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
IP4000 Color Printing Problem
If you have a monochrome option, I would use that.
I'm guessing that your old black and white photo's (which I'm thinking you scanned in may have a sepia tinge which the printer is emphasizing, and if you only want black/white prints, no need to print with colour.
2answers
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
old marine
old marine
ZJ Limited
ZJ Limited
