Question about Apple iBook G4 Mac Notebook
Problems installing RAM card
I'm trying to install a 1GB memory card into my ibook G4 (late 2005 model) but it is requiring an unusual amount of force to insert the card in the expansion slot, in addition to simply not inserting properly (or at all). I'm getting really nervous that the memory card is going to snap in half or something, or that I'm scratching the card itself, so was wondering if someone could speak to how hard I should be forcing the card. The top corner is fitting but the bottom half isn't, almost to the point that I'm beginning to think the card is too big. The "geeks" at best buy recommended this kingston model and I've done extensive troubleshooting online that has assured me that the card is the appropriate size - both in dimension and memory size. The little metal brackets around where the card should be installed are also proving incredibly problematic - despite that the memory card has a pair of cut-outs seemingly meant to enable the card to be installed without snagging on these clips - even when I have the card tilted at the appropriate "30 degree angle" as directed by the diagram provided underneath the keyboard by Apple. Can someone please offer some advice! Thanks!
    Scholar:
  • 51 Answers
Have you installed any RAM into this iBook Before? One way to double check that you have the correct RAM is to take the one out that is alreay in there and line them up and see if the width and height are the same. Critical is to see if the little grove is in exactly the same place, when you have the two sticks of RAM lined up with the Pins facing each other and the edges of the RAM also line up.
When installing the RAM the angle should be about 30 degrees, and when the pin edge of the RAM has slotted in out of view lower the angle of the RAM and as you continue to push it in level the RAM out. It does require a 'little' force, but nothing to break it. When push home all the way you should be able to flatten it out so the clips that hold it in place engage, if it is a little tight take it out and try again. Should this work put it together and try it out. When you have started up the unit look to see if the new RAM is registered in the 'About this Mac' under the Apple menu. If not the RAM is not sitting right in the slot. Open again and push it home. Should only be a Milimetre or so.
Let me know if this works or you need further help.
Good Luck
Posted on Jul 14, 2008
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Looking for instructions on how to install blue tooth card into e-mac g4
Here ya go.
should give you what you need
[PDF] iBook G4 (Late 2004) Getting Started (Manual) File Format: PDF/Adobe Acrobat - Quick View
install one, see “Installing an AirPort Extreme Card or Additional Memory” on page 51. ... You can also find information on the Apple Bluetooth ...
manuals.info.apple.com/en/ibookg4gettingstarted.pdf - Similar
Jul 12, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
While I was on the internet my ibook g4 locked up. I tried to restart but it continued to lock up. I tried to reinstall OS10 but the computer locked up in the middle of the install. I have replaced the...
If by "lock up" you mean the mouse/keyboard freezes and the machine becomes unresponsive to any input, and you have already replaced the memory with a known good memory, you may have a logic board problem (not necessarily, but quite possible).
First place to start is by running the Apple Hardware Test from the DVD that came with your unit. (The test is specific to each model of Mac, so don't try to run it off someone else's DVDs unless they have the same model you do.) If you no longer have these, an Apple-Certified Macintosh Technician will have a special Apple DVD containing the collected tests for all models of Mac.
Oct 18, 2009 | Apple iBook G4 Mac Notebook
Not able to install system software
Leopard is not really suited for the iBook G4.  I would recommend you go back to Tiger and see if that gets rid of your lockup.  Leopard is more suitable for the Macbook.
Oct 17, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Typing lags in quark
It sounds like your computer does not meet the recommended requirements. They are listed below for version 8:
  • G5 PowerPC processor or Intel processor (G4 minimum)
  • 1GB RAM (256MB minimum)
  • 1GB hard disk space
  • DVD-ROM drive
  • If you only meet minimum requirements then it is likely to lag as you are experiencing. To fix the problem you could try and install more memory in the system.
    Aug 18, 2009 | Computers & Internet
    Adding memory to a a75-s211
    How much memory did it have before you removed the 256Mb RAM?
    If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
    Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
    Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
    I tried to erase and re-install my os x(on ibook g4;1.33ghz;1gig ram;40gig hd) but it seems to have a problem in the middle of installation.it always stops on the installation of the worldbook 2005 then...
    Try to do a custom install and skip that application, if it works then it was that app. If it still gives you a issue, then you need to go to the utilities on the cd and check the HD to make sure there are not bad sectors.
    Jun 21, 2009 | Apple iBook G4 1.2GHz 12" w/ Combo Drive...
    My G4 466 graphite won't see my low density 512mb sdram stick!
    As long as the 512MB RAM chip is running at 133Mhz it should work, it may have compatibility issues with the other RAM in the unit. Try removing the other RAM first if it does not work after that you probably have a faulty piece of memory.
    Oct 16, 2008 | Apple Computers & Internet
    Memory upgrade for ibook g4
    Hi-
    you can check a lot of sites where you can view and check onthe step by step guides how to install or upgrade the memory of your ibook, check this links
    http://www.memorystock.com/memory/AppleiBookG412GHzM9419LLAMemory.html
    http://www.edgetechcorp.com/memory/apple-ibook-g4-memory.asp
    http://www.powerbookmedic.com/Take-Apart-Repair-Manuals-p-1-c-258.html
    just select the type of memory card that you are using and it will lead you to a page where you can download a pdf file of the instruction.
    Hope this helps, pls rate as fixya if it helps. thanks!!
    Jun 26, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
    Apple iBook G4 Mac Notebook Logo
    153 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
