Question about HP LaserJet 2420 Printer
My printer shows 49.FF05 SERVICE ERROR. No matter which key I press and no reactions.
  • 2 more comments
  • Anonymous Apr 02, 2009
    49 ff05 service error for hp 4650
  • Anonymous Mar 26, 2014
    solve the problem
    What does this error message mean and how do we clear it?
  • Anonymous Mar 28, 2014
    49.4 C18 service error
  • 300 Answers
A critical firmware error has
Try following these steps -
1. Press CANCEL JOB to clear the
print job from the printer
2. Turn the printer off, and then
turn the printer on again.
3. Go to http:
support/lj2420, or
Click Download Drivers and
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Posted on Jul 14, 2008
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to for more information
May 27, 2015 | HP LaserJet 4350n Printer
49.ff05 service error hp laserjet p5200
there is nothing wrong with your printer!! it is a connunication issue from the computer to the printer... cancel the document that you tried printing and try reprinting it again.. to clear the error remove the USB cable or Network cable then turn off the printer.. then back ON while the printer is in the ready state re attache the USB or Network cable and reprint the document :-)
Jan 02, 2014 | HP LaserJet P3005d Printer
No display clean ram and switch on ok but not reddy 49.FF05 ERROR in valied nand key press any key
ISSUE: A 49.x service error appears on the HP Color LaserJet 4500 or 4550 printers display, and other unexpected errors may be displayed such as:
  1. Turn the printer off, and then turn it on again. If the 49 error clears, proceed to Step 9.
  2. If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card, which is located on the formatter, (see Figure 1 for location), or any third-party devices, if installed.
  3. Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
  4. Turn the printer on, using a cold reset. If the 49 error returns, turn the power off, and unplug the printer. Remove the formatter, and check that the parallel I/O board is firmly installed on the formatter board.
    NOTE: To perform a cold reset, turn the printer off, and hold down the GO button while turning the printer back on. Remember to remove the Jetdirect card (if installed) before performing a cold reset. (The Jetdirect card is located on the formatter).
Mar 28, 2013 | HP LaserJet Office Equipment & Supplies
49.4c18 error and 49.FF05 service error for hp printer P3005x
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
try hard reset for your printer. Do this steps.
1.Shut down the printer.
2.Open the top cover of the printer and remove the print cartridges.
3.Close the top cover of the printer.
4.Press the power button on the printer to turn the printer off.
5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
6.Disconnect the power cord from the back of the printer for one minute.7.Reconnect the communications cable to the printer.
8.Reconnect the power cable to the printer.
9.Press the printer power button to turn the printer on.
10.Open the top cover and reinsert the print cartridges.
11.Close the top cover and print the calibration page.1
2.Restart the computer.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 11, 2011 | HP LaserJet P3005 Printer
LaserJet 4250 49.FF05 SERVICE ERROR
This is a common issue with HP printers, usually caused by updated programs such as Adobe Acrobat.
Here is a link to a tip I wrote on how to solve this problem. click here
Apr 19, 2011 | HP LaserJet 4250n Printer
49.ff05 error
A 49 error on an HP printer is caused by the printer receiving a commmand it does not understand. It is the computer equivalent of "huh?" The first step to fixing this is to ensure that you have the most current firmware installed for the printer. Curent version is 02.120.3. To find what is installed, restart printer to clear the 49 error and then printer a configuration page. On the upper left hand side of the config page you will find the firmware revision listed. If it is not 02.120.3 then follow instructions below. You can print a config sheet by using the up or down arrows to change the menus until it displays information. Press checkmark and then on the next menu use the up/down arrow till you find configuration sheet and press checkmark again. You may need to ensure that there are no print jobs pending so that the printer does not have another 49 error while you are trying to do this.
Firmware upgrade instructions:
Click here to access HP site where you will find the lastest firmware revision. If you are using Windows, download the first option which is the EASY INSTALL. Run the file once downloaded and it will automatically start and confirm which printer you want to upgrade.
Mar 13, 2011 | HP LaserJet P3005d Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
I have unplugged and replugged, shut down and restarted my printer but the FF05 Service error prompt for my HP Lasejet4250tn wont go away. suggestions?
I have been through the service manual, and googled the FF05 error. I could not find it anywhere except with a 49 in front of it. 49.FF05.
Power off the printer and then loosen the two screws for the JetDirect card. Pull the card out about 1/2". Now power on the printer and see if the error comes back. If it doesn't, print out a config sheet. If still no error power off and plug in the jetdirect, power on and if the error comes back, get a new jetdirect card.
Now if you get the error with the jetdirect removed, remove the rear left side cover(as you stand at the rear of the printer. This will expose the formatter. Open the formatter door. There is a latch at the front of the formatter, pull it out and the door will swing open. See if you can see a memory DIMM in there. If yes, power off and then remove the DIMM or DIMMs(depending on your memory size). Power up and see if the error comes back. If yes, there is one more thing to try - NVRAM initialization before replacing the formatter. DIMMs arn't $500.
Get back to me after you try the stuff mentioned above, if you still get the error.
Mar 11, 2010 | HP LaserJet 2420dn Printer
first upgrade the firmware from HP page
second try to print from diferent port
third if the 2 other solutions dont work for you, replace the formatter.
Jul 01, 2008 | HP LaserJet 2420dn Printer
HP LaserJet 2420 Printer Logo
22,172 people viewed this question
Ben Johnson
