I am printing on a Canon Selphy ES1. The media package - ink and paper combined - it has just been replaced with a new pack and I get the following error message on my Mac: "Failed to receive data from printer - 9782. On the printed the display states "Cartridge has been changed. Insert appropriate Cartridge. I have inserted the appropropriate cartridge three times - each with a new cartridge but I get the same messages. Any thoughts?
  • LeSeb Jul 18, 2008
    I have similar problem with my ES1 when printing from the Mac (works fine on standalone mode)
    error message : "cartridge has been changed"
    But problem does not happen when printing with E-C cartridge (card size) !
    so I think maybe a problem in the driver that does not support well E-P cartridge type?
    I use Mac OSX version 10.5.4 with Canon SELPHY ES Printer Driver for Mac OS X version 2.1
    Any help please ?
    Thanks!
Check "Printer Properties" so that the cartridge is set to color if E-Pxx cardridge is mounted and set to B/W if E-PxxBW cardridge is mounted...(xx stands for number of postcards) // Kjell.sundling@hotmail.com
Posted on Nov 08, 2008
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
I have a Canon i9900 printer. I have used the daylights out of it. Can printers start to print blurry if they are wearing out? My prints look fine at 100% on the monitor, and when I print the picture it...
Problem : Ink does not eject properly or Printing is blurred or Colors are Wrong or White streaks appear.
Cause 1 : Ink tank is not seated properly or the ink tank is empty.
Action : Check that the ink tanks are firmly seated in the print head and reseat them, if necessary.
Check that the correct ink tanks are installed and that they are in correct order.
Check to see if all the orange tape has been peeled off. If a part of the orange tape remains, remove it thoroughly.
If an ink tank is empty, replace the ink tank.
Cause 2 : Print head is misaligned.
Action : Align the Print head.
Cause 3 : Print Head nozzles are clogged.
Action Print the nozzle check pattern to check for uneven ink output.
When specific color is missing from the nozzle check pattern, clean the print head.
Cause 4 : paper is not loaded with the print side up.
Action : Checl that your paper is loaded with the correct print side facing up.
Note: Follow the instructions packaged with your specialty media for loading and handling.
Cause 5 : Incorrect paper type.
Action : Windows : On the Main tab of the printer driver, confirm that the selected Media Type matches the paper loaded.
Mac : In the Print dialog box of the printer driver, select Quality &
Media from the popup menu, and then confirm that the selected Media Type matches the paper loaded.
Cause 6 : Glossy photo paper other than the Canon specialty media is used.
Action : Select Other Photo Paper from Media Type. It may resolve the problem. Load one sheet at a time and remove each sheet as soon as it is printed.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon i9900 InkJet Photo Printer
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
Selphy ES1 printer switches on,
remove all the connection go to control pannel printer and default ur Selphy Es1 printer
Jun 18, 2009 | Canon SELPHY ES1 Thermal Printer
SELPHY printing too dark
I have some experience with color profiles, after trying to fix this problem by changing the profiles in Photoshop, letting the printer manage color, leting PS to do so, and every possible thing.... I found that increasing brightness, and 2 points of saturation on the printer dialog pretty much prints what you see on the iPhoto screen. I have the Selphy 740 not the ES1, but might be the same....  abee9c5.gif
May 08, 2008 | Canon SELPHY ES1 Thermal Photo Printer
Cannot print from my PC
totally unload the driver and software. Then go to printer/faxes - install new printer and when the new hardware prompt comes up - ignore the CD prompt and select from list instead. select Canon select Model- then try come back with the result.
Sep 18, 2007 | Canon SELPHY ES1 Thermal Photo Printer
198 people viewed this question
jasbo
jasbo
