Question about Samsung HLP4663W 46" Rear Projection HDTV
Color wheel or fan?
My Samsung HL-R4266W DLP picture went blank when I heard a pop and got the 3 blinking lights. Just replaced lamp, but still same problem. Hear grinding, loud humming noise and vibration. How do I know if it's the color wheel or the fan? Can I replace these myself? Called tv repair and they said color wheel alone costs $300, but I see on line for $100. Thanks!
  • jenneo Jul 14, 2008
    Thanks. I'm going to go ahead and order the color wheel. I'll followup after I get the part.
  • Anonymous Mar 28, 2014
    replaced lamp and color wheel making loud noise
  • Samsung Master
  • 8,617 Answers
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Posted on Jul 14, 2008
  • Sonny Berry
    Sonny Berry Jul 14, 2008
    If you need help installing it let me know.Thanks
    Slinteriors
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP TV HL-R4266W is making a noise when I Turn it off. It sounds like the fan is rubbing on something. I took the back off and all 3 fans look fine. Could the noise be the Color Wheel and is...
Yes, the Color Wheel would be the only thing left. I am not sure about this exact model but the Color Wheel in other Samsung models are replaceable.
Hope this helps,
Skyassoc
Jul 06, 2009 | Samsung HL-R4264W 42" DLP HDTV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
465 people viewed this question
Jerry Greenberg
Jerry Greenberg
