Question about Singer 7462 Mechanical Sewing Machine
When attempting to sew rather thin material the main presser foot has not enough downward pressure to keep the material from sliding around. This is on a Singer 111W. Works fine on leather etc. I thought that the little cleats on the bottom should clamp against the main foot while the smaller foot lifts up and goes forward.
  • Anonymous Mar 22, 2014
    bought a used singer 5825. bobbin winder doesn't work. and can't find a way to increase downward pressure on presser foot..material "floats" too much
  • 323 Answers
This machine was not designed to sew THIN material. It is an upholstery machine and it will never sew thin fabric very well. You can try a smaller needle(size 16 or less) and shorter stitches. There is also an adjustment to raise and lower the walking foot located on the backside of the machine. It can be recognized by the wing nut holding it in place and that it slides up and down when it is loose.
sewman7
Posted on Jul 14, 2008
The tension isn’t right. I got my walking foot on & the tension up on 6 & I still gotta pull on my project. Very frustrating. Help
hi u need to get equilibrium between the thread tension at the top and below so that u can have a perfect stitch. i can assist if u can chart me on watsapp +2348189956612
Oct 09, 2017 | Sewing Machines
Is it possible to change the presser foot pressure on a necchi 200? I looked in the manual but can't find anything.
Newer computerized models usually have a pressure adjustment in the form of a dial on the left side of the sewing machine head.
Older machines generally did not include that information in the manuals. It is usually a screw that is accessible from the top of the machine, inside the cover--most often directly above the presser foot. Sometimes it is a plunger-type button--the further down it is depressed, the tighter the pressure.
http://makeitsew.biz/presser-foot-pressure
FWIW, if your machine does not have a pressure adjustment, you might try using other presser feet, ie roller foot, walking foot, teflon foot.
Sewing Machine Pressure Settings for Machine Quilting
Bernina 830 Record Review
Feb 19, 2017 | Necchi Sewing Machines
The pressed foot lifter won't hold the material, I can push it up down turn it around this is not right
Are you saying the presser foot has very light pressure on the fabric? If so, most machines have the ability to increase the pressure the presser foot applies to fabric and feed dogs. It depends on your machine's make & model where & how that pressure is adjusted. Older machines usually have a large skrew or knob at the top of the needle bar that tightens down on a big spring, thus the tighter spring increases the pressure. Newer machines sometimes have a dial usually located on the top left or side of the machine head. (Consult your owner's manual.)
The Best Kept Secret on Your Sewing Machine Sew Daily
Parts of Sewing Machine Pressure Adjustment
Under Pressure Adjusting Presser Foot Pressure
May 25, 2016 | Sewing Machines
The tention is not holding the material in place slips around when im sewing .
Do you guide the material with your hands while sewing?
Jul 07, 2015 | Sewing Machines
Change the presses foot
Check the user manual. You can view, download, or print the manual free from the viking website - http://www.manuals.husqvarnaviking.com
See page 11.
Changing the Presser Foot ! Turn off the main switch
  1. Make sure that the needle is in the highest position. Pull the presser foot towards you and slight pressure downwards.
  2. Line up the cross pin on the foot between the spring and the presser foot ankle. Press back until the foot snaps into place
Aug 12, 2014 | Husqvarna Scandinavia 100 Sewing Machine
Can't raise the pressure foot on my Brother Project Runway Sewing machine. I raise the plastic lever but it does nothing
Open machine face cover you would be able to see what happen to your presser bar. If you can raise the lever but the presser bar not response Or if you can push up the presser bar easily with your hand, the presser bar tension screw is loose. Upper part of the bar would have the tension/presser spring, press up the presser bar till you can feel enough tension to press the material then tighten the tension screw which is located behind the bar.(Most machine you can access the screw thru a small entry at the back of machine, right behind the bar itself. You may have to repeat this until the bar have enough presser to press the material. Hope this is helpful.
Jan 17, 2014 | Singer Sewing Machines
Wont sew heavy fabric
Not sure what machine you have. Sounds like there's so much force from the pressure foot that the feed dogs can't advance the material. Can you reduce the tension on the presser foot incrementally? If not, try releasing the presser foot but keep some tension on it manually.
Mar 24, 2013 | Husqvarna Sewing Machines
I have a Finesse sewing machine and I was sewing some placemats but it suddenly stopped feeding the material although it keeps sewing (foot moves up and down). According to the book I have checked the...
Can you see the feed dogs moving?
un thread, raise the pressure foot then manually turn the flywheel towards you and watch the feed dogs (the teeth that move under the needle plate). If they are not moving around and coming up above the needle plate then one of two things:
either you've accidentially disengaged the feed dogs, check the manual for instructions to reengage, sometimes a knob, button or slide, often on the front base or around the back of the free arm.
If they are engaged but not moving up at all, then something has gone in the drive to them, usually a gear in the free arm area. In which case, take to the shop for repair.
Jul 01, 2011 | Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
91 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
