Its a GPU problem.
It can be overcome by doing reflow technique.
You
need to do following.
1. Uncover ur PC casing
2. Locate the
nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU
fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get
scrambled display/wavy screen, but wait for 5 minutes.
7. Press
reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10.
Connect the power supply pin back as it is.
11. Power on ur PC.
thats
all.
Removal of fan power, makes the GPU to get high heat, it a
reflow technique.
Remember, not to touch the GPU portion (heat sink),
as it may be in higher temperature.
Try this, it works most.
Clarifications:
[email protected]
hi again , if i reinstall my windows 7 ,and i install this nvidia forceware xp ,it will be working ,cause this driver what u linked here it's a xp driver.
