Whirpool Washer is not Spinning or drainning - Washing Machines
  • 41 Answers
Pump or filter blocked it wont spin if still full of water
Posted on Jul 14, 2008
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
My whirpool washer will not spin. Any suggestions?
heatman101 .
Oct 11, 2010 | Whirlpool AWM6140 Front Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Whirpool duet washer. Drum pulley loose
If the pulley doesn't fit the shaft anymore, it may have sheared a metal key between the shaft and pulley center. If it did, you may have to replace both the key and pulley. If the key is intact and the set-screw is only loose, just tighten the screw and you're home free. Make sure the belt has not been damaged--replace it if so. The belt should be fairly tight when things are back together.
Oct 28, 2009 | Whirlpool GHW9100L Front Load Washer
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On my whirpool washer LD light lights up and many times drain cyc
ld stand for long drain there is something in your pump or your drain most likely the pump you need to clean the pump or maybe even replace it if need be
Dec 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool top load washer
things to check, to narrow it down:
  • is the timer stopping prematurely? (timer problem)
  • is the machine draining the water as fast as usual? (water pump problem or something blocking water flow)
  • is it spinning as fast as usual? (clutch problem)
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 11, 2008 | Washing Machines
Washing Machines Logo
376 people viewed this question
Top Washing Machines Experts
