Question about GE Kitchen Ranges
My installation manual says to use a 3 wire 40A cord. The range is rated for 14.1KW at 125/250volts which converts to 59Amps. What size wire should be used to the breaker pnl? How can a 40A cord carry a 59A load? The main wires on the range appear to be #12 or at best a #10. The model # is JB968SOl5SS. What am I missing here?
  • 147 Answers
SOURCE: wireing the baseboard heater
I can help you if you still here.
Posted on Nov 06, 2008
  • 1214 Answers
SOURCE: No Power ... Display Blank
There may be, but your problem is not any of those. You apparently have a short to ground somewhere that need's to be located and repaired.
Posted on Jan 24, 2009
  • 10865 Answers
SOURCE: 240v circuit wiring to run my new Dayton Heater (3Vu34A)
Thanks for your quick reply. First of all let me cite the UL position on this issue:
Avoid using an extension cord with your air heater. If you must use an extension cord, it should have a rating 1.25 times the wattage rating of the heater. For example, you should use a cord rated at least 1,875 watts with a 1,500 watt heater.
That being said I strongly recommend that you spend the few extra dollars to install a double pole breaker and the proper size wire and outlet to make this a completely safe project. If you are going directly from a panel to the area of the heater I would use 10-3 with ground and do the job right.
In the long run I can assure you that you will feel real good about doing this job by the Underwriters Laboratory specification
Posted on Jan 29, 2009
muttandjeff
  • 359 Answers
SOURCE: Main breaker tripping
replacing the main is a possibility and i saw someone suggestion to ck load on each leg of power , also a good idea but one thing i have also seen do this is a loose or corroded connection in the meter base or disconnect which causes a process called electrolysis that is a flaking away of the conductor itself in the meter base or disconnect feeding the panel main breaker and causing heat build up internal to breaker and making it trip but if you replace the main that is the time to check all these connection and it would not hurt to apply a little no lock or some other brand of oxidation inhibitor
Posted on Feb 07, 2009
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
How to download movies on the mp3 player
  • Make sure that your MP3 player can also play videos. It should say right on the box for your player whether it can. it should also say what file types the player can use.
  • Install a video converter for your MP3 player if needed. Look to see if one came on your installation CD. Look online if you need one. Consider a Sansa Converter.Install any drivers on the installation CD at the same time, allowing your computer to recognize your player when you plug it in. This process starts automatically after inserting the CD in the computer's CD drive.
  • Convert your video into the right format and size. Many videos on your computer aren't in the right size to view on a small MP3 player screen, so you'll need to convert them first. Check the manual for the proper size.
  • Hook up your USB cord to your computer and to your MP3 player. This cord should have come in the same package as your player.
    Open your video in whatever folder you converted it. Drag it over to your MP3 player folder, located within "My Computer" field.
    Some converters will automatically download the video to your player after it is converted. Provided by E How
link below will show how it is done
How to Add Movies to MP3 Personal Media Player
Jan 21, 2016 | Visual Land ME-975L-8GB-PRP V-Touch Pro 8...
Tip
How to install your new range cord
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously owned range that you have brought to a home thats new to you
black wire going on the left,red wire on the right& the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where the link was removed just a minute ago oldtech2332_1.jpg
3 WIRE CORD
The 3 wire cord goes just like this see the 2 wires on the outsides of the cord going to the black/red wires .The wire in the middle of the cord goes on the middle terminal on the cord block
on Aug 13, 2011 | Kitchen Ranges
Tip
Oven Cord and Wiring Oven for 3 Wire or 4 Wire
If you have an Electric Oven, Range, or Cooktop and need to change the style of cord that you have on the appliance or if you just need to install a cord on a new cooking appliance, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
Remember to ALWAYS make sure that all power is disconnected BEFORE beginning your work!!
On the back, underneath, or on the side, of your range or oven will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look something like this.
You will have a red wire, a white wire, and a black wire, on the other end from the plug.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. or larger wire and a couple of crimp rings. Green wire is preferable.
The connection will look something like this.
If you have a four wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the appliance. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
This connection will look something like this.
When converting from a 3 wire to a 4 wire you just REMOVE the bonding strap or wire and hook the green wire to the frame. If you are converting from a 4 wire to a 3 wire then you ADD the bonding strap or wire. It gets hooked from the center lug to the frame.
Always make sure that the outlet that you are plugging into is wired correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole circuit breaker of the required amperage. The wiring needs to be large enough to support the breaker size that you use and the requirements of the appliance. For 30 amps. use 10 ga. wire, for 40 amps use 8 ga. wire and for 50 amps. use 6 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new appliance or convert your existing appliance cord. Recheck all your connections before turning the power back on to the appliance.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Apr 06, 2010 | Ovens
Hotpoint oven manual
I found that GE offer a specific plug which allows four connections:
Universal range power cord (4W / 4' / 40A) WX09X10035
You may need to find out if you have such a socket or how to produce such a socket.
Dec 18, 2013 | Ovens
Good evening. I have a Whirlpool freestanding electric range GFE461LV that I bought in 2009 and for the first time I will install it. This is because I am from Brazil and since 2009 we were expecting our...
It is 220 V with a neutral conductor. If you are installing it in the United States, local electrical codes may require using a 4-wire cord (two wires for the 220 Volt connection, the neutral and the cabinet ground); otherwise you can use the neutral for grounding with a 3-wire cord. The cord and two-pole circuit breaker in your electrical service panel should be rated for 50 Amperes.
You can download complete installation instructions from Whirlpool. You can also find the Owner's manual and other documentation at the Whirlpool site.
Jun 20, 2011 | Whirlpool GFE461LV Electric Range
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
1 or 2 circuits to create 2 phase?
How to explain this? your new drop in unit will require a 220v circuit capable of a specified amount of amps. Typically 40, 50 or 60. Should be noted in the manual and on the unit itself. If your original oven and cooktop were electric, then each one was probably hooked up to a 220v circuit. The problem is figuring out how many amps were supplied for each. The simplest way is the go to the panel and find the breaker for the old oven and cooktop and read the numbers (or amps) on the on/off switch. If either breaker has a number the same or greater then the drop in unit says it requires, then your all set. If the drop in unit says it requires 52amps and one of the breakers says 60 on it, your fine. If the drop in unit says it requires 44amps and the breakers are 30 or 40, then you got a problem. Usually a breaker is installed that is the maximum amps allowed for the size (thickness) of the wire connected to it. You CANNOT connected a 50a breaker to wire only rated for 40a. Note the size difference of wire connected to a 20a breaker with wire connected to 40a breaker. If the drop in unit requires more amps then the original units used, then a larger wire will need to be ran from the panel to the drop in unit (Not cheap). Now if the original oven used a 30a and the original cooktop used a 30a, then its possible ( 80% of electricians wouldn't do it because of liability problems) to use both wires together to create 60amps, but both wires (actually a total of 6 wires, 2-120v wires and 1 ground wire from each outlet) would need to be in the same outlet box for the drop in unit connection.. I could (and probably should) try to explain more, but I'de probably just confuse you more. GOOD LUCK!
Nov 28, 2009 | GE Profile JT952 Electric Double Oven
I need the electrical rating for a JennAire JES9860
all ranges should be on a 50a plug
good thinking to ask'
wish my brother had
hed still have his house
anyway
if your read the range plug ua it says 50a
Oct 24, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Pioneer 12v car amp rated at 1200 watts max requires ? amp fuse
Hi I would suggest 40A (i know guys will disagree) but you shouldnt be running at full 50A. Fuse are often rate at 50% - 75% of the actual consumption. By the way, 8 guage @40A will give you about a 2% drop at 5 feet. Maybe consider heavier for 40A?? Just a suggestion
Jul 24, 2009 | Audio Players & Recorders
Where can I BUY THE cords at.
I've never seen the ad for a weed thrasher but, as far as a replacement cord goes. You can buy a extension cord of the same size and install it. Just cut off the end. The wires within the cord need to be the same size or bigger, never smaller. Also it's important to replace a 3 wire cord with a 3 wire cord. You can use a 3 wire cord with a machine that came with a 2 wire cord, just cut off the green wire at the machine end. Your wire colors should be white, black, and green. Black and white are your power wires and green is your ground. Usually black and white are interchangeable but, on occasion switching them may make the unit run backwards so install them in their original position. Write down where they where hooked up and install your new cord in the same places.
Mar 23, 2009 | Weed Thrasher Replacement Cutters As Seen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
