Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required.
The information is normally free of
charge.
I hope this helps.
Network for spare part supplies as required.
charge.
I hope this helps.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
YOUR
Attempt
If
ONLY
The usual
appliance.
Hope this helps.
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
If
ONLY
The usual
appliance.
Hope this helps.
If
ONLY
The usual
appliance.
Hope this helps.
The magnetron may have either failed
or is not being supplied with the extremely high voltage required to
run it.
Make sure the !!!!capacitor is discharged!!!!!
before attempting any sort of repair.
switches first then the high voltage diode with either an AVO model 8
on high resistance range for short circuit, the feed fuse on the
Hope that helps.
