Unable to display the folder. Microsoft Outlook could not access the specified folder location. XP And office 2002 Outlook Do you know how to fix it
  • 80 Answers
Hi im wesley. what might work is finding the folder you are trying to open manually from your pc then open it with outlook
Posted on Jul 14, 2008
Cannot open
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
Important notice for users of Office 2003:
To continue receiving security updates for Office, make sure that you're running Office 2003 Service Pack 3 (SP3). The support for Office 2003 ends April 8, 2014.
If you're running Office 2003 after support ends, to ensure that you will receive all important security updates for Office you need to upgrade to a later version such as Office 365 or Office 2013. For more information, see Support is ending for Office 2003.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
On the Change Office User Settings page, expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box.
For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
More information
When you run the Custom Installation Wizard, on the Change Office User Settings page , you can make changes to any Office user setting on the computer where this MST is deployed. When you click Miscellaneous PST Settings, you can specify a default location for .pst files.
In the Default location for PST files box, you can use environment variables such as %USERPROFILE%. For example, you can give the location %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
However, you cannot specify a file name instead. For example, you cannot specify %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\%USERNAME%.PST.
If you do this, an error occurs when you try to start Outlook.
Jul 04, 2013 | Computers & Internet
Outlook cannot display the view. The specified view cannot be found
Outlook provides you a number of views to set. Yo can create a customized view for different folders and elements. You can check the complete steps here :
http://office.microsoft.com/en-us/outlook-help/create-change-or-customize-a-view-HA010120901.aspx
May 29, 2012 | Microsoft Office Outlook 2007 Academic...
How to open Outlook 2010 email files backed up to a CD?
You will need to import the data from the PST file back into outlook . It should go into a personal folder
After this process you can then copy the files into your email inbox or leave them in a personal folder or create a personal folder on a server mapped drive and then import email data to this folder so it gets backed up hopefully on the server. If you bak up the server..
https://support.office.com/en-us/article/Import-email-contacts-and-calendar-from-an-Outlook-pst-file-431a8e9a-f99f-4d5f-ae48-ded54b3440ac
May 24, 2017 | Microsoft Outlook 2010
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
I have done something to outlook 03. When I try
I can't fix the problem you told me but you can use your same account on hotmail.com(unless your used a different server but most will work) that should have all the tools you had on outlook just not everything will be at your desktop.
Feb 11, 2010 | Microsoft Outlook 2003 for PC
Outlook 2003 inbox says: unable to display folder
Please try locating your PST file, and run scanPST on it. here is more information on how to run scanPST:
http://support.microsoft.com/kb/287497
Jan 23, 2010 | Microsoft Office Outlook 2003 for PC
Cannot open Microsoft Outlook
I think you are trying to run outlook in Compatibility mode. Which is why Outlook window isn't opening.
You can try following solutions.
1) Search Outlook in start menu search box then right click on outlook and select Open File Location. You can see the following image for this.
2) Now select Outlook and right click on that & select properties.
You can see the following images for that. cannot-open-microsoft-outlook-w3i35ygaym0a2mtgexp5w2fh-2-2.png
3) Now click on Compatibility tab and Uncheck the checkbox "run this program in compatibility mode" and at last click on Apply then OK. You can see the following image for this.
Now, I hope Outlook will work properly.
Jan 22, 2010 | Microsoft Office Outlook 2007: Windows
Outlook 2003 won't open "Unable to open the Outlook window"
Hi, i would recommend this, if you have not tried it already to go to this site hp site and search for the driver there, by entering the relevant information. I have a HP laptop and there where I get my drivers.
Oct 25, 2009 | Microsoft Windows XP Professional
How to download outlook for ms office 2003
You do not want to download the Free Outlook 2003 (any site offering free outlook 2003 is a scam/spyware filled) You can download Outlook free as a trial from Microsoft. Do not trust and Outlook or other Office software from any place besides Microsoft.. You want to download Microsoft Office 2007 Pro which is paid software. MS Outlook 2003 is not free. Go to Microsoft.com
Oct 21, 2008 | Microsoft Windows XP Home Edition
Can locate publisher
According to the product specs., Office Pro 2007 did not come with Publisher: Read:
In addition to the core Office XP programs - Microsoft Word, Excel, Outlook, and PowerPoint - Office XP Professional includes Microsoft Access 2002, the Office XP database solution that helps users store, access, and analyze their data.
You have to purchase Publisher.
But good news, You can download OpenOffice from www.openoffice.org. It is free and comes with a Publisher compatible program. OpenOffice.org boasts two mid-level layout programs -- Draw and Writer -- each of which is far more versatile than its name suggests. You may have to go through the tutorial but it Free. and works well in windows.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
