Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd52725 cap replacement
Followed your instructions on ordering the kit (with 8 caps) and the cd.
i have reached the point of removing the chassis, but have a problem..
the power cord that goes from the chassis to the set , i don't know how to remove it.
also, the cd gives instruction of disconnecting two connectors located under the cover on the right side of the set (CN1 and CN2 connectors)
i don't see these two items on my set.
and where is the power board? do i have to remove the covers with the holes in them?
thanks...steve
  • steve n Jul 15, 2008
    i have made progress...no's 1 and 1A are bad caps...
    how do i remove the wiring (no's 2) properly? i skinned the wire on one trying to remove
    (i'll tape it)
    again , thanks for your execellent advice
    steve
  • steve n Jul 19, 2008
    just a note...thanks to people like you who are willing to help us, the uninformed...this repair, parts and labor, (my labor) was a total of 60.00....
    thanks again
  • Mitsubishi Master
  • 8,617 Answers
The power pwb is on the opposite end of the chassis opposite the Input locations. I believe on tha model the plu assembly gets removed from the case and stays with the chassis block. I believe CN1 and CN2 are the ballast connections you need to remove a metal shield on the ballast Circuit to see the connections.
Posted on Jul 14, 2008
  • Sonny Berry
    Sonny Berry Jul 15, 2008
    Those wire clips just unplug from the very top edge. If you look closely at the very top edge of those connectors you will see where they seperate and unplug. Replace all the caps that come with the repair kit even if they dont show any visible signs.
  • Sonny Berry
    Sonny Berry Jul 20, 2008
    Youre welcome, thats why I recomend that site to people cause they help you repair your set and it doesnt cost you an arm and leg to do it. Glad your mitsubishi is up and running again
Timer light blinking green
Thats a common problem usually caused by failed caps on the DM and The Power Boards. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps and the CD with repair instructions.
Sep 19, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a Chevy 2500 pick up truck. My son thought he'd replace the spark plugs. He removed the distributor cap, didn't understand it and now the truck won't start. He did not replace any spark...
firing order for 5.7 v8 is 1-8-4-3-6-5-7-2 mostly all of the chevy v8s are the same firing order. the rotor button in distributer turns clockwise, the cylinder numbers are 1-3-5-7 on drivers side, 2-4-6-8 is on passengers side. To get started get your distrutor cap[new one] look on the top you will see a #1that's where you begin you must know if if rotates clockwise or counter clockwise start in that direction then follow the firing order and cylinder line up. good-day!! if cap is not marked, just pull out #1 plug, put a straw or similar in plug hole on top of piston. turn engine over by crank in front of vehicle with a wrench, when the piston comes to the very top just before it starts going down. this is tdc. and rotor button should be pointing to #1 wire on dist, cap. follow from there. good-day !!
Aug 09, 2011 | 1994 Chevrolet Silverado 2500
Blinking green timer light after power outage.
Failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM/ Power repair kit from www.tvrepairworld.com which contains the replacement caps and the CD with instructions.
Aug 06, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Power timer lamp flashing, tv will not power up
The caps on the DM and power boards need replacement. Yo can get the repair kit called the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which has the caps and the CD with instructions.
Jul 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The timer button on my tv keeps flashing and wont allow me to turn the tv on.. what do i do
Replace the capacitors on the DM and the Power boards. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com the kit contains the upgraded caps for both boards and the CD with repair instructions
Jul 19, 2010 | Mitsubishi WD-62725 62" Rear Projection...
What is the firing order for a 1995 chevy k1500 and what order do they go on the cap ? 1-8-4-3 ect where is number 1 on the cap and do they go counter clockwise or clock wise Thanks joe
Hello, I have attached a figure to help you out. The point with out the black dot is Number one on the distributor. Hope this helps. Please rate.
Apr 21, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Mits WD52725 DM Board
You can find any of the PC Boards for Mitsubishi TVs at Discount Merchant.com for 69 dollars
May 29, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
133 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
