Question about Maytag MGR5750 Gas Kitchen Range
Problem with oven preheating
My Maytag oven takes forever to preheat. I replaced the igniting unit a few years ago, but that was because it would not bake anything. This time it will eventually bake, but takes forever to get to the predesignated temperature. Every so often I hear the gas pulsing instead of a steady gas flow.
  • Ed Nock Aug 12, 2008
    I have the same problem with my gas pulsating instead of flowing at a regular rate. Anybody know what to do and/or the cost to fix?
  • michaelbruye Jan 16, 2009
    The heat exchange acts like there is not getting enough air to reach the complete tempature
  • 639 Answers
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
My Maytag Gas Oven MGR5750ADW preheats on certain temperatures and not others. For example it wont preheat at 350 degrees but will preheat at 380 degrees. At 350 we smell gas.
What you have is an ignition problem get this corrected before you experience a delayed ignition, the hot surface ignitor pulls enough amps 3-3.4 to power up and open the gas valve but ignition did not take place reason you smell gas don't know how old unit is ignitor may be weak good on draws 3-3.5 amps burner ports may be dirty or the bracket that the ignitor mounts too may have bowed away from the burner
Jan 29, 2015 | Maytag MGR5750 Gas Kitchen Range
Problem with Maytag oven
Sounds like it may be the igniter failing
Feb 13, 2014 | Maytag Ovens
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have Jen Air expressions built in oven. It takes forever for the oven to preheat. What could be the problem?It is about 13 years old.
Both the broil and the bake heating elements are on during preheat. I would take a look as it appears that your broil element needs to be replaced.
Jul 12, 2009 | Ovens
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Maytag MGR5750 Gas Kitchen Range Logo
632 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
