Question about Ricoh Office Equipment & Supplies
Ricoh FT4215 copier with U5 error code
When I changed the toner cartridge the machine would not ready and showed the toner low light ( down arrow into the toner holder with little circles?)
Sometimes a error U5
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
-check if the toner waste bottle is full,if so please empty it.
-are the consumable developer within life?
-if so , then check the vsg/sp settings
Posted on Jul 16, 2008
Tip
Toner empty,toner low,no cartridge
hello, this is a appear when replace new toner
some time machine didnt recognize toner.
press menu#1934
display ready tech
press menu &left arrow key display new cartridge enter twice.
and restart machine error message is over
on Aug 14, 2010 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Samsung 4623FN when i refill the catrdige second time it shows me as. End of Life replace with new catridge..
  1. Prepare a new cartridge of the color (K, C, M or Y) you wish to replace.
  2. Ensure that the printer is on with all covers closed, and that the Toner Low warning, Sleep, or Ready status is displayed.
  3. Press the right%20arrow%20black.jpg Right arrow button to display the menu.
  4. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Reset Menu is highlighted:
  5. Press the right%20arrow%20black.jpg Right arrow button once, this will enter the reset menu as shown below:
  6. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Change Toner X (where X is K, C, M or Y) is highlighted for the toner you wish to change:
  7. Press the Right arrow button to start the removal procedure. The printers panel will read Please wait, then after a short delay the printer should display a red error light and the message Replace Toner X, where X is the relevant toner cartridge:
  8. Open cover D.
  9. Hold the toner cartridge knob and tilt it toward you.
  10. Remove the empty toner cartridge from the printer.
  11. Take the protective materials off of the new cartridge, and gently shake the new toner cartridge a few times.
  12. Take the new toner cartridge out of its package, and remove the plastic protective cover from the toner cartridge.
  13. Insert the new cartridge into the printer.
  14. Close the toner cartridge cover.
  15. Close cover D.
  16. If you need to change another toner cartridge, repeat the above procedure from Step 1.
TO view pics of the steps click here
Apr 19, 2011 | Samsung SCX4623F Laser All-in-One Printer
The printer is not working, toner is always showing low toner and not give the print.
hello try to do this
press menu#1934 and right arrow key disply show ready tech
press menu button and press left arrow key
display show new cartridge.press enter button twice. then restart your printer.error message didnt display
Aug 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
After refilling the cartridge the toner low red light is still flashing. How to stop the flashing light?
Did you remove the plastic tab from the toner cartridge?
It would not be the first time I have been called to a faulty printer to find the cartridge had not been correctly installed.
You say in your post that you refilled the toner. Did you replace the whole cartridge or pour toner into the machine?
Every machine has different toner have you checked that it is the correct type?
Also some cartridges have a chip embedded that tells the machine that it has been replaced it is possible that this has failed either in the cartridge or within the machine.
Jul 03, 2009 | Ricoh Multifunctional SP 3200SF...
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh ft4215 problem
do you get an error code on the display, or does it flash open door/out of toner/out of paper/paper jam or what ?
mikey
Mar 13, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
126 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
