FixYa.com
Drive Cases
Generic problem for all Acomdata Drive Cases
External hard drive
posted by KD7APK on Jul 14, 2008
light blinks and makes noise with the rythm of the light but computer doesn't recognize there is a hard drive attached.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by CowboysFanZ, posted on Jul 19, 2008
If you are using a USB port for the drive.. be sure you have disconnected whatever you had in the port before if it was in use. USB sometimes has issues removing one device and adding another. Try rebooting the PC with NOTHING in the USB port, and then connect the drive to the USB and see if it is recognized.
If that doesn't work be sure you have USB 2.0 drives and not 1.0. Your drive needs a 2.0 USB to work.
This Problem Also Relates To: Acomdata Samba USB Enclosure Kit Black: Samba USB Obsidian Black Enclosure Kit. Create your own high-perform... IDE / EIDE, Serial ATA, Parallel, USB, USB 2.0 Drive Case Acomdata Samba USB Enclosure Kit Red IDE / EIDE, Serial ATA, USB Drive Case Acomdata HDEXXU2E3 (DHHDEXXU2E3) Drive Case
Can you Help with these Drive Cases problems?
Drive Cases
Mad Dog
My Mad Dog MegaVault 3.5, I... Answer This...
Coolmax F1-U2 3.5in USB 2.0 Xtreme Files OS...
bootablee probs
i have pc facing probs... Answer This...
Vantec 1 Bay NexStar 3 USB 2.0 External Drive...
can't put data on hard drive
i tried to put a file that is... Answer This...
Kingston Data Express DE110, S21P104...
Reg Removable disk
Hi ! I'm praveen can you pls... Answer This...
Vantec NexStar-3 External 3.5inch SATA&USB2.0...
hard drive wont be reconised by...
my nextar.3 120 g got drop on... Answer This...
Repair Service
Find Drive Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
