Question about Samsung HCM4216W 42" Rear Projection Television
Samsug rear projection tv, everything looks green
I replaced the color wheel about a year ago and everything was fine. Now all of a sudden everything looks green, but picture is otherwis okay. Any suggestions?
    Novelist:
  • 132 Answers
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Posted on Aug 15, 2008
I have a Panasonic pt-61lcx65 and everything works fine but in the picture there a outline of green and shades of green on the picture, and I've tried everything to get to the service mode to adjust the...
I own the same set in the 44" version. These often need a "prom flash" with the panasonic programming jig to correct for color spots" in the picture. Mine did, over 3 years ago and has bee ok since.
Apr 30, 2014 | Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Samsung HLR5067WAX/XAA 56 inch, rear projection. Replaced lamp on it two years ago, was working fine. This morning a sudden thunderstorm blew in. When the power came back on, the cable picture...
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Apr 26, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Color of the picture is faded/green
Hello Jdillon917,
I understand what you are saying, however the devil is in the details in reference to your problem. Let me explain, DLP Televisions use what is called "Color Wheel Technology". A wheel made up of primary and secondary colors spin at a synchronized rate with the Luminance Video signal and this along with the changing of the mirrors of the DLP processor creates the color that you see on the screen (This is a high level description, but it covers what is happening). Now what you are experiencing can happen if the sync between the signal to the color wheel and the DLP processor is off center, if the color wheel is out of alignment, or if the signal to the DLP is drifting. The bulb "light" is working but something happened to interfere with the sync between the color wheel and the DLP processor. I would suggest getting this looked at by a DLP qualified TV technician, because of the nature of this problem. In addition I would request that you have the technician do a certified alignment after the problem is taken care of.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 19, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Picture problem
I have the exact same problem a month ago. I replaced the two STK392-110 ICs with the STK392-110T adn everything went back to the way it was.
Jul 01, 2008 | Toshiba TZ50V61 50" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
157 people viewed this question
Jerry Greenberg
Jerry Greenberg
