Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony tv lead light blinks
When you press the power butten the chassis need to open but the lead light blinks reaptdly.
  • 4,234 Answers
The standby light should blink in a repeated count separated by a 3 second pause. If you can post the count here, we should be able to provide you with details about the problem circuit and what will be required for repair.
Posted on Jul 14, 2008
The key indicator light keeps blinking
one of the buttens are pressed or stucks try also to open it and to clean the points of contacts.
May 17, 2014 | Televison & Video
My 321 has power but the bulb light under the compartment is not on
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
also you may need to replace the motor brushes if there are no other faults.
Nov 23, 2013 | Golden Technologies Health & Beauty
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Lcd not turning on
May i know is it the power led light blinking or just steady?
Jul 20, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Stand by led blink 4 times
my tv is FD Trinitron WEGA KV-HA21. when i press the power button it starts but after about three secounds it trips to stand-by and starts blinking four quick succession at intervals
Jul 20, 2008 | Televison & Video
when you press the botton the light comes on then goes off
Jul 19, 2008 | Televison & Video
there is an internal short that needs to be eliminated about 250,00 to fix it
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Asus Board MOdel Number P4BGL (845 Mxl) is giving an error called Chasis opened or tampered.?
I read a solution of your problems, i did not ry this. But i want you to try in your motherboard: this was qoute by
" 9. anonobomber, 07-05-2002 09:51 read the manual from your motherboard, I'll quote it for you; Chassis Intrusion Lead (4-1 pin CHASSIS) This requires an external detection mechanism such as a chassis intrusion monitor/microswitch. The sensor is triggered when a high level signal is sent to the Chassis Signal Lead, which occurs when a panel or light detector is triggered. This function works with an optional ASUS CIDB chassis intrusion module (see your vendor for more details). If the chassis intrusion lead is not used, a jumper cap must be placed over the pins to close the circuit.
pinout 1[+5volt] [power supply standby] [chassis signal] [ground]
in order to supress the messages you are getting you will need to get a jumper to fit over the chassis signal and ground to bypass the chassis intrusion detection circuit.
This has nothing to do with resetting the CMOS. For board specific locations of the pins check for the manual pertaining to your motherboard"
Jan 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
