Question about Pioneer Televison & Video
Equipment: Sky box to Toshiba Regza XV50 digital Toshiba to Pioneer DVR-550HX-S via HDMI cable Location: France TV has downloaded Sky channels and all channels are OK. However, it is seemingly impossible to record either directly or set the Pioneer timer to record. Any suggestions ? many thanks trevor smith pp. roger white faberquinque@yahoo.co.uk
Went to avforums.com
Posted on Jul 16, 2008
Magnavox tv has intermittent pixelation and snow breaking through on picture on all channels. Have had cable service out twice to replace digital DVR box but still a problem. Brand new HDMI cable too.
If your TV is connected to the cable box with only an HDMI cable, the problem should either the cable company equipment or outside interference. A bad HDMI cable with cause intermittent or continuous complete loss of picture. Try plugging the HDMI cable from the cable box into a different TV (if you can borrow one) then you can prove if the problem is with the TV or the cable equipment. Maybe a neighbor has a ham radio that is causing interference? (They will have a tall antenna at there house, so easy to see.)
Dec 22, 2014 | Magnavox Televison & Video
The TV model is Sanyo DP32648. DVR Cable Box - Motorola DCT6412 III I have a DVR cable box connected via an HDMI cable to the TV's HDMI 1 slot. I have had the TV for around a year now and haven't had...
If you have the DVR connected to the TV with the Coaxial and the HDMI that is probably causing the problem I work for a Cable company and have dealt with this problem on numerous occasions. Try just disconnecting the Coaxial cable from the cable box that should fix this issue.
Dec 02, 2010 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have a Toshiba Regza 42 inch LCD flat screen tv. Sometimes when changing channels the scrren turns green. There is still sound. The only way to bring the picture back is to turn the tv and dvr off and...
I suggest you do firmware update first, then you can use another source such as a DVD plug in to the same HDMI input when the problem appear, to make sure where is the problem, if it is the on the TV, replace the main board.
Part # 75012465 cost approx $300.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
May 02, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba Regza "blink"
It's your TV switching resolutions, nothing you can do about it. Sorry.
Jul 28, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
95 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
