My washing machine had ligths flashing and is now filling and draining but not spining please help
  • mairt Nov 01, 2008
    I have the same problem with my machine. It goes through a normal wash and at the stage where it goes into the first spin, I can hear a single click as something disengages, then all the lights start flashing and it makes a noise like it is pumping water out.
Next time spell lights l-i-g-h-t-s
Posted on Jul 21, 2008
  • 41 Answers
What make and model is it and which lights were flashing
Posted on Jul 14, 2008
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Afrer washing it stops spining and all the lights start flashing the door will open but the washing is still soaking wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Hotpoint Washing Machines
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
My washing machine is taking water but not draining and not spining
This problem may be related to a bad lid switch. If the level sensor works, that is it stops filling up when at the correct level then it is looking for the lid switch ( To start working safely!!).
Regards.
Aug 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Aug 19, 2009 | GE Profile WPSR3100W
After setting to wash unit will fill then cycle its self through all cycles without rotating or spining at all , and then drain , all in about 30 seconds. any ideas experts?
Hi, Is this a whirlpool model? Please give a model # so I know what machine you have for better instruction.
Thanks
Vic
Jul 15, 2009 | Washing Machines
Kenmore 22422 not draining or spining
If it is same as in photo (Frigidaire built) your drain pump is probably blocked/jammed. You have small children?? Kids socks seem to find their way to the pump often.....
Dec 26, 2007 | Kenmore 43142 Front Load Washer
Misti, usually no spin, no drain is a broken lid switch. part #3949238. See if the switch is busted off from the screws. Catriver
Dec 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
