Unwanted Message My monitor constantly displays a "menu is locked" or "menu is unlocked" message in a large black box in the upper left hand corner of the screen. How do I get rid of it?
  • Computers & ... Master
  • 1,689 Answers
Generic Answer:
With most models of these monitors, hold in the menu key for more than 10 seconds.
If the above does not work, call the manufacture tech support. The monitor may need service.
Jerry G.
Posted on Jul 15, 2008
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
There is a large black area in the upper left hand corner of the screen
If it is a square box, it is usually a text box. It can be fixed by turning closed captioning off. Either hit the CC button on the remote until off appears. Or go in to the menu find closed captioning or text and turn off. If it is not a defined box, it could be something inside the tv.
Oct 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
Out of range message
check the unit/CPU to the others monitor or open then make a clean the VGA card and Memory..good luck
Jun 25, 2009 | X2Gen MG17J 17" Monitor
My main menu button is locked and don't know how?! Any ideas? Its a dell multimedia 19" flat LCD.
if its a w1900 this is a known setting. Press the menu button on the right hand side of the TV (second button UP, just above power/standby. Now, WHILE THE MENU LOCK MESSAGE IS BEING DISPLAYED, press CH ^ and VOL - AT THE SAME TIME. Menu unlocked message should be displayed.
And you're done.
Might take a couple of tries - this tv/monitor is a bit fiddly...
Feb 21, 2009 | Dell W1900 19 in. HD-Ready LCD Television
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Computers & Internet Logo
801 people viewed this question
David Payne
David Payne
