Question about HP 1040 Plain Paper Inkjet Fax
Not printing faxes
The ink level is fine, but fax incoming pages come out blank?
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Check the ink cartridges head, they may be dry
Posted on Jul 15, 2008
After changing ink cartridge incoming faxes won't print. Does something have to be reset?
Some machines recognize you changed the ink cartridge and some do not. If you shut it down and restart it, this usually helps it reset.
Feb 28, 2015 | Brother Mfc-j6710dw Multifunction Printer...
Why do my incoming fax sheets have black ink all over them can not read fax
well i think that the paper u use in ur fax machine creates a colour bleed over it. so i reccomend u that use low porous papers. but do not use blotting papers or porous papers as while printing the fax page, porous papers soak high ink and it gets scatterd over.
another sollution- please check the cartridges because if the cartridges leak, then it may lead to spread blank ink over paper......
check these simple steps and then if the issue persists inform it again....
Jan 14, 2011 | Office Equipment & Supplies
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Low ink message with incoming fax, no fax but printing works fine
Unplug the machine for 3 minutes and plug it back in. sometimes this will reset everything. good luck
Feb 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Cartridge problem of the fax.
Are you saying the fax appears to print but is blank or it does print but is not in a fax form but freestyle with no background format. Changing a cartridge will often upset the apple cart. see if the printheads could do with a clean. Make sure you reset ink level sif your unit does not automatically do this. Try a reset too by turning unit off, unplugging all cables, replugging all and turning back on. Post back if no good.
Nov 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
HP 1040 Plain Paper Inkjet Fax Logo
174 people viewed this question
Ben Johnson
