Question about Frigidaire Washing Machines
Hit wrong button
I hit the delay start button and I want to stop that and just push start.
  • 1 more comment
  • nereservices Oct 05, 2008
    looks like its going to reset by then all the same settings are highlighted when it resumes including delay!
  • hippiechick2 May 21, 2009
    holding for 5 seconds doesn't stop it, the 8hour button is still on!
  • 41 Answers
Press and hold start/cancel button for 5 seconds and machine should reset
Posted on Jul 14, 2008
How do i override the delay start function
According to page four of the manual linked below, you can simply hit START after selecting 1. Menu item, 2. Crust colour, 3. Loaf size, 4. Mix-ins, 5. START or Delay Start Timer.
If the bread machine is running, and you wish to overide the Delay Start Timer, NOTE down the other options selected for Bread Type, Crust Colour, Loaf Size and Mix-ins; then press and HOLD the STOP/PAUSE key for 3+ seconds to re-initiate the breadmaking process. Re-enter the options, and re-start the breadmaker using no Delay Start Timer (Hit START in step 5.) or enter a new Delay Start time and then hit start
https://www.cuisinart.com/share/pdf/manuals/cbk-200.pdf
Feb 15, 2015 | Cuisinart CBK-200 Bread Maker
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
Delay timer is flashing and locked ini that position
did you select delay wash.... it sometimes happen by accident try delay time button to stop delay wash the hit cancel....
Jan 31, 2011 | Kenmore HE3T Washer
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Can't set time delay.
Would your start button be stuck? check to see if there is something keeping it pressed in? if not your control star button could be shorted...let me know
Aug 23, 2007 | Kenmore 24 in. 16462 / 16464 / 16469...
Washing Machines Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
